Question about Whirlpool LSR5132PQ Top Load Washer
How do i connect the water intake and outflow of water
  • onthethejob1
    onthethejob1 May 11, 2010
    do you mean ,,the fill hoses,,and drain hose,,,installation
  • 21 Answers
My Energy saving Hobart dishwasher hums and clicks but no water or drainage HELP!
You maybe have something clogging the intake, outflow valve. Sometimes with age, they chip apart. I have replaced ours and found tiny pieces.
Check your model update of schematics and see where this might be located, which will tell you if you think you can replace it.
Oct 17, 2017 | Hobart Dishwashers
Whirlpool dishwasher
The float valve may be sticking or defective.
Feb 19, 2017 | Whirlpool Dishwashers
Ok to turn off water to heater?
yes it is best too in case the heater starts, there is nowhere for expansion.
Feb 12, 2017 | Water Water Heaters
My unit says prime and no outflow.
"Prime" usually indicates the pump is sucking air. Sometimes the valve in the bottom of the water reservoir gets stiff or gunked up; if you turn off the B60, remove the water container and drip some water into the water intake until it's full, turn the unit back on, replace the water reservoir and that little amount of extra water should be enough to allow the pump to work properly.
Apr 24, 2016 | Keurig B60 Coffee Maker
Water heats up then trips off red button
The lit red button may be an indicator that the water temperature inside the water heater flow channel has become too hot. If the outflow facet is adjusted to allow more water outflow (opened more) the water temperature should drop some and therefore with increased water flow, the temperature inside the water heater will also decrease. Or, if there is a manually adjustable outflow valve on the water heater, adjusting it to a more open position would also decrease the internal temperature.
Sep 17, 2015 | Water Water Heaters
Slow running water at the return of in ground pool
Maybe your local Pool repair shop is useing a 'super-soaker' water gun to jet milk into your pool at night hence drumming up business. Don't laugh I heard of some doing that. You mentioned this occured after you cleaned, maybe you dislodged something that found it's way into the intake that is causing a blockage. Check all valves and filters again, there may have been something that was in pipe and has now found it's way to the filter. You mention that the pressure is up. If the gauge is on the outflow side of the pump then the blockage is between the pump and the outflow to the pool.
Jun 04, 2013 | Hayward Pool & Spa
Have a teel pump motor runs but want pump water
Either the impeller is not on the shaft tightly or there is something clogged in the intake or outflow pipe.
Jan 23, 2013 | Dishwashers
Have been using a 16 Gal. 6.5HP Shop Vac to vacuum water and pump out water through water hose. Then It quit pumping water out the water hose. Still vacuums water and will fill tank till auto shutoff,...
Look for a clog near the pump intake--not likely that the hose itself is plugged. You might try running water back through the hose to the pump to see if you get outflow from the pump intake port. If the pump is powered from it's own motor, then the motor may have seized due to debris or possible bad bearings. Hope this helps!
Oct 30, 2010 | Garden
Metal rattlin sound at intake-outflow at 4 to 5 seconds when burner kicks on, tempurature spike to 110 plus, shuts off and blower runs for awhile and then repeats, allso had metal shavings from blower when...
If you take apart your header (intake and outflow) you will find two mech. inside it. One is your by-pass assembly the other a thermal gov. both control water flow through heater If they have problems your water can sit inside heater and boil causing knocking and eventual problems. If you open this up you might as well replace both due to the labor involved. This should fix the problem. Good luck.
Jan 17, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Whirlpool LSR5132PQ Top Load Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
