Question about Asrock 845GV (P4I45GV) Motherboard
Continuas restart when i power on my ups connected to computer the computer gives no display but the processor fan continues to run.please help me,i have no money to afford a second mother board.
    President:
  • 2,961 Answers
Check your cmos battery as it may be too flat to continue to the P.O.S.T If you find it to be flat replace and then you will have to reset the time and date in the bios setup screen when prompted. If the continuas re booting persists, turm pc off and then on again pressing F8 as it boots and hopefully you get into the safe mode menu and you eill have to highlight the line that reads Last Known Good Configuration, press enter then allow a re boot.
Posted on Apr 23, 2007
Acer aspire m3640 PC power comes on, give three beeps but no display
One Long and Two Short Beeps
video display circuitry issue
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
Aug 05, 2012 | Acer Aspire M3640 Drivers Recovery Restore...
I have a gigabyte p4 pc, when i power it on the fan runs but it gives out a continuous beep. checked ram, processor on another motherboard, cleaned the motherboard, checked for loose cards and cables
The continous beep usually means a memory failure (RAM) or video memory if a plugin card is used.
Check to be sure the unit sees all of the memory, a weak power source( without AC adapter) could cause a partial failure of one memory card.
Another fault would be that the battery is very low on charge and won't accept any charge.
BAD Battery.
hope it helps
May 31, 2012 | Gigabyte GA-8LD533 Motherboard
Power on but no display processor fan running power switch light off
Power light possible means nothing, maybe a burned out led.
No display: Try feeling the cpu heatsink to see if its getting warm. If it is cold after 15 minutes running, the CPU may have failed. If warm, move onto the graphics. If using onboard, try using an aGP card and see if you get a display then.
(I'm assuming that you get a beep on powering up? If you get no beeps at all, confirms CPU is at fault, if 8 beeps on start up, probably graphics. any other beep codes, post them and I (or somebody else will help)
Dec 28, 2010 | PC Chips : PC-Chips M909G P4 /FSB...
No any display & sound then i power on my PC my pc is intel 815t abit st6, red led is always on but no display? can any one help me??????
First check your num lock key led if it on and off when you press num lock then your cpu gives diaply to monitor perfact.
Then check your display connection from monitor to cpu.
When you power up the computer pressF8 ket then enter in enable vga mode.Then go to control panel -> display->property ->settings.
Then change screen resolution to 1024*768 then apply and ok .
But if you still not get dispaly then
-> Open cpu cabinet.
-> Refix RAM meory clean all dust from motherbord chip set .
-> pull cmos cell for 15 minutes.
-> Reattch ATX power supply to motherbord.
-> Refix processor it is bottom of processor fan.
Please rate my solution if it help you .
Thanks for using fixya.
Jul 20, 2009 | Computers & Internet
Continuse restart my computer
Your CPU is overheating
1) Turn off computer and remove case side
2) remove fan from "heatsink" do NOT remove Heatsink "Usually this is stuck with solidified heat paste"
3) clean all dust and dirt from heatsink and fan.
4) vacuum out case Include behind power supply and video card.and any other fans
5) use stiff brush and vacuum outside of power supply
Reboot and see if still restarts if not everything OK
shutdown PC and refit case side.
This is a common problem on a lot of computers as the environment they are used in is usually dusty.
I do mine every 3/4 months and have no problems like this
Please when works give me a fixya
Jan 26, 2009 | Intel D101GGC Motherboard
Computer restart
yes the problem as you discussed was the processor's overheating. first, you need to open up the side cover of your casing then switch on check vissually if the fan of the processor is spinning if not then you need to replace this. and if this is spinning upon power on, the power supply will be checked its voltage.
Mar 25, 2008 | Computers & Internet
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Asrock 845GV (P4I45GV) Motherboard Logo
82 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
