Question about Kenmore 63942 Dryer
Dryer stopped 1/2 way through cycle-hit start, drum won't turn
The belt is ok - it was making a funky noise for a few weeks, but working ok - sounded like maybe something was just stuck - when I hit the start button, something in the timer is low bussing like it is trying to start but can't ??also, when it stopped 1/2 the clothes were drying
  • onthethejob1
    onthethejob1 May 11, 2010
    a thats iffy..i need you to open dryerdoor hold the door switch and let me know what happens,,please be careful..also listen to see in which area of the unit the hummings coming from..
  • 318 Answers
If the unit is sounding like it is struggling to start then you most likely have a bad bearing in the motor. they will usually get noisy and the become worse and louder. the unit also will run for awhile and then stop with the clothes not dry, if you try to start it it will go but will stop again shortly later.
if this unit is fairly old, like more then 10 years, you might want to look at the price of a new unit versus replacing the motor. the motor could cost you about 100-120 bucks if you put it in yourself and another 100 bucks if you pay someone to put it in for you. most new dryers will cost about 250-300 bucks, so the choice is up to you.
Posted on Dec 31, 2008
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
LG WM3431hs drum won't turn on dry cycle
Broken drive belt tho your model number is not for a dryer.
Feb 04, 2018 | LG WM3431 Front Load Washer / Dryer
Dryer starts, drum turns a few times then stops. On its own, repeats the attempt to start but has the same issue. For a while it would actually start and complete drying cycle after 3-5 attempts. Now it...
if you can still here the motor running it could be the belt slipping,, try running the dryer with a very light load in it ,,if it works ok,,its the belt slipping and it cant turn a full load anymore,,change the drive belt!
if no motor sounds its the programer,,,pricy part!!!
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
I have an Amana model NDG7800AW. A few weeks ago
The roller to the belt tensioner is binding causing to make the warbling noise.The bearing needs to be replaced which comes with the roller. A new belt is advisable as well when replacing. The stalling problem could be also from the belt being stretched or the timer relay is weak
May 01, 2010 | Amana NDG7800AW Gas Dryer
Dryer stopped working
The clicking noise is probably the timer switch working ok...no problem there
Sounds like you could have a broken belt, that will keep your drum from turning.
If you have a front load machine, remove the front, that will expose the drum. You should see the belt on the drum, if it is not there then it is broken.
You would then remove the drum and replace the belt, while your at it you should go ahead and lube the drum rollers at the shaft with a good grade of machine oil...Like 3 in One oil...it will extend the life of the rollers and help to keep them from making noises later.
I hope this helps
Oct 02, 2009 | Whirlpool LER4634J Electric Dryer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Kenmore 63942 Dryer Logo
67 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
