Question about HP OfficeJet G85 All-In-One InkJet Printer
HP G85 faxing more than one page a problem
I am unable to send multifple pages from this fax machine. It only sends one page at a time. Any solutions there?
How i can use fax without handset
Posted on Jan 30, 2009
  • tesfhannest Jan 30, 2009
    Hp officejet G85 has not handset i do understood how i use fax
    I have new Hp officejetG85 but do not understood how i can use fax to send & receive without Handset please
Why can't I fax more than one page at a time?
IF IT JAMS OR TAKE ALL THE DOC AT THE SAME TIME CLEAN OR REPLACE ADFRollers and separation pad. TEMPORARY SOLUTION IS use sanded paper gently to give surface of roller and adf pad, moer grip
Apr 23, 2013 | HEWLETT-PACKARD HP 2140 Fax
Fax does try and send but then stops and prints an error page err 388 each time?
The remote fax machine might be defective.
Solutions
  • Try to verify this by sending the same fax to other fax machines. If these transmissions are successful, then notify the user of the remote machine to make them aware of the issue.
  • If the fax fails when sending to other machines, turn it off for 10 seconds, turn back on, and then try sending again.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Jan 05, 2011 | HP Officejet 6500 Wireless All-in-One...
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HP J4680 Office Jet All-In-One Printer
How do i get a report of the fax i sent?
Follow the steps to setup the Fax sent confirmation report.
  4. Press OK .
Other confirmation reports in the same menu are :
Hope this is helpful
Thank you for contacting FixYa.
*Rating and comments invited on this solution
Nov 11, 2010 | HP OfficeJet J4580 All-In-One Laser...
Fax sends certain pages in duplicate
If it only happens with that one vendor, the problem is almost certainly either on their end or somewhere in the interaction between the two fax machines.
The most likely answer is that their fax machine has a problem receiving some pages (either because the line is noisy or for another reason) so it has to reprint them. You could tell your vendor to try turning off error correction on their fax machine and see if that makes a difference.
Hope that helps.
Jul 05, 2010 | HP 920 Plain Paper Fax
WHY DO I GET A BLANK PAGE AFTER EACH FAX?
The fax machine that is sending you the fax may be also sending a confirmation page that is not needed or compatible with your machine.
I have an older machine that prints a confirmation page after each fax. People on the other end sometimes receive a blank page after each fax that I send them while my machine prints a mostly blank page with only a single line of text at the top with the date and time.
Feb 01, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Error 441 seems to take all pages but receiver get aapx. 1 paragraph & the rest is blurred - same incoming
This means that an error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing) or the line speed drops to an unacceptable level.
Solutions
Check that the phone cord is plugged in correctly and is not cut, creased or damaged.
Make sure that the phone connection terminal box is not damaged and that the cable connecting to it is not damaged.
Try the fax at a different time when telephone line conditions have improved.
Oct 08, 2009 | HP OfficeJet d145 InkJet Printer
Once I send a fax, I am unable to send another without turning the machine off & back on. When I try to use it again to fax, the button beeps and the screen says busy.
what is the brand of your fax machine.... i have an hp officeject3500 series all in one...when im sending fax after it says 1 doc sent/faxed, it will take like a few mopre seconds before i cud use the handset or send a new one...
and also r u trying to send to a different number or the same???
if the same number and u want to send mutiple documents uve to prepare the docs ull be sending like after feeding the first page immediately feed the next one before 1st page is out of the machine..
dunno if this will help u but if check the setting and ifs okay maybe the best way or next step is to report it to a technician where u got ur fax machine...
Sep 11, 2009 | Office Equipment & Supplies
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My hp officejet G85 won't successfully send multipages faxes Can you help me with this problem?
Not sending multipage faxes I will assume the pages are not feeding correctly. If this is the case replacing the entire ADF would be the easy fix.
Not available new from HP as far as I can tel but available if you search G85 ADF.
If machine is terminating the connection try reseating th LIU this is the board the phone line plugs into. part C6735-60009
Hope this helps
Mar 06, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
96 people viewed this question
Ben Johnson
