Re: 1998 Saturn will not start after new stereo installed
It means the wiring is wrong check and look fo the ignition cable and make sur it's properly secure see the wiring is all a big maze in thesecars u have to make sure everything is wired correctly the battery wire as well
You will have to drop the fuel tank down far enough to access the top of the fuel tank. You will probably have to remove the exhaust system and all hoses and electrical connections. Disconnect the connector from the sensor, pry it out of the top of the fuel pump module. Be careful not to break the top of the fuel pump module. When installing the n
Sounds like the the Bendix is bad in the starter, which pushes out the drive gear to engage the flywheel. You'll need to replace the Bendix or the starter. It's a bit tough to get to the starter, it is underneath the intake manifold.
p303 is a cylinder 3 missfire I woul first check the coil and then the ingnition module, Then if this dont work you could have a bad injector. If after testing and still no fix you should check the compression in that cyl.
