Question about LG WM-2277HW Front Load Washer
Door gasket leaks at the bottom when spray nozzle goes on
  • 640 Answers
Happy new years,,i believe you mean when the recirulating pump comes on about 4 to 8 mintues into wash.....open door and fell if any lint stuck up there if so use a needle nose pliers to pull out..check the bellows or gasket around door and make sure your not ripped ,,or missing a peace...now this is cheaper than buying new gasket...unplug unit ..than remove door switch and put 1 washer on the back of each screw ,,but put washer on inside of unit between panel and door latch ...this will push latch back and make door come forward so to be tighter...im here,,onthejob
Posted on Jan 01, 2009
DISHWASHER LEAKING FROM CENTER OF BOTTOM OF DOOR
It's possible the bottom spray arm isn't rotating, and all thenwarermis being sprayed directly at the center of your door. Check this first. end, check the spray arm isn't damaged, as this can alter the spray pattern.
Jan 12, 2018 | Kenmore Dishwashers
How can I fix my Frigidaire PLD4375RFC Dishwasher that leaks from bottom door even after new door gaskets 154576501 and 154701001.
It sounds like you are fixing the wrong area. If water is coming down between the inner and outer door panel and following the wiring harness, the leak is inside the door. Either from the soap cup mounting or the rinse agent area which I think is the same unit on your model. There is a gasket behind that part. Also check the inner door if its plastic for any possible cracks.
Apr 22, 2015 | Frigidaire PLD4375RFC Dishwasher
Gentron 3500.. Starts fine, but idles up and down..runs better when choked or partialy choked..but if I loosen the bottom screw on the collection bowl on the carb it leaks fuel but runs smooth as a k
You've got an air leak somewhere. Running better with the choke closed is the clue. Air is entering somewhere else and by closing the choke you are basically adjusting the air/fuel ratio to be more correct.
With a combustible carb spray and red nozzle pipe, you can lightly spray around the carb as the engine runs and see where the running changes and that's your leak point. Keep the spray away from the carb inlet so you don't get misled.
The carb could also have gunked up gas deposits. Clean the carb also.
Re-check it.
Sep 15, 2017 | Gentron 2800w rated 3500w peak...
Leaks under door
IF LEAK IS FROM AROUND SIDES OR TOP OF DOOR, IT COULD BE THE DOOR GASKET, FIRST MAKE SURE THAT THE DOOR IS NOT MAKING CONTACT ON THE SIDES WITH CABINETS, THEN CHECK THAT THE SPRAY ARM ROTATES FREELY INSIDE AND NOT SPRAYING DIRECTLY ON EDGE OF DOOR. THE GASKETS ARE REPLACEABLE. IF LEAK IS COMING FROM BOTTOM OF DOOR THEN THE PIECE IS CALLED A BAFFLE AND IS ALSO REPLACEABLE. MOSTLY THE PROBLEM IS OTHER THAT DOOR GASKET OR BAFFLE. THE DOOR DOES NOT CLOSE COMPLETELY WHEN CONTACTING THE CABINETS.
Mar 10, 2010 | Whirlpool Dishwashers
Maytag Dishwasher WU482 had a big puddle of water in front of it tonight. Other than the door gasket, is there anything else that could be wrong?
a pluged or should i say a partially pluged lower spray arm nozzle redirecting the water spray under the door causing it to spray water in a direction it shouldn't be, causing your leak.
another spray arm could again have a partially pluged spray hole causing water to spray in a direction it shouldn't, or more forcefully so it blows past the door seal..
the float switch could be bad allowing an overfill, but thats usually more substantial.
best of luck,
ttfn
Oct 25, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Frigidaire GLD2445RFS0 dishwasher has developed a door leak
Make sure the lower spray arm ends (there are 3 arms) are snapped together all the way. One of ours had come apart and was spraying water out the end of the one arm. It was enough to "spurt" water past the plastic gasket at the bottom of the door. I snapped the arm back together and BINGO. Free fix.
Sep 29, 2009 | Frigidaire Dishwashers
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kitchenaid KUDS25SHBL1 dishwasher that is leaking from the bottom of the door. I replaced the main gasket around the body that the door seals against, and it is still leaking.
Have you removed the outer door to check if the leak is coming from inside the door . also check the bottom door seal ? also check the around the soap dispenser as I have had to silicone around them to keep them from leaking before..let me know if this helps at all.
May 11, 2008 | Dishwashers
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Door leak
Br, couple of things you can look for here. Check the vent, you can just pop this out. Sometimes there is a buildup of gunk which will hold water during wash and leak down between the door. There is a seal there, part number 974782. Another thing is to check the upper spray arm for cracks or splitting. This can send a direct flow of water into the vent. There is also a seal at the bottom of the upper spray arm, part number 3376846. I was fooled by a leak like this once, it turned out to be a clogged vent...Catriver..post back.
Sep 30, 2006 | KitchenAid 24 in. KUDS25 Built-in...
LG WM-2277HW Front Load Washer Logo
94 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
