Question about Frigidaire GLTF2940ES Front Load Washer
Washer won't start a cycle
When we press the start button to start a cycle, the washer waits about a minute and then the letters "ddo" come up on the LCD. Normally as soon as start is pressed, water will begin entering the washer but not now. I verified the water supply is turned on and that the door is shut all the way. Any advice?
When you took out the dispenser door, a magnet may have fallen out. from the front part. you may need to tape a new one in.
'dispenser door open'
may be the error bc the magnet isn't there (acts as a sensor
Posted on Dec 29, 2007
It means the door lock is open, unplug the washer and it should reset the lock it did for mine when i got the code
Posted on May 10, 2007
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 17, 2014 | Washing Machines
Wm3470hva no power
Unplug the washer from the wall wait about 5 minutes, plug it back in to the wall and press the power button. You should see all of the lights on the front come on and start cycling. wait about 2 minutes and you should be ready to start washing.
May 06, 2013 | LG Wm3470hva Wm3470hva Front Load Washer
Ddo code comes up after closig door
Hello gracehamada - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check the reed switch. Try resetting the washer by unplugging it or flipping the household circuit breaker off. Wait approximately twenty minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately.
Feb 13, 2013 | Frigidaire GLTF2940ES Front Load Washer
Computer shows ddo &won't finish the wash
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
Dec 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
"Pause" will not give way to the selected cycle
Turn off the machine then unplug it for at least 15 minutes and plug it back. Turn the washer on then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it. Include also the exact model number of the machine if the foregoing instructions don't seem to be applicable with your machine.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Oct 03, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front load washer with ''ddo'' code
The DDO trouble code means that the detergent(D) dispenser(D) door is not closed properly((O)open).
The door uses a reed switch and a magnet to send the door closed signal to the control card.If the
magnet becomes dislodged you will get this code.You will need to have the magnet replaced in
its proper position to clear this code.
Apr 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
My washing machine keeps giving me a error 20 code and dosent finish the cycle
E20 is a general error code to get to the real problem try this..
Reading Error Codes2.gif 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash2.gif. let me know what code come up... hope it helps
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
E20 flashing mid cycle
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jul 01, 2009 | Zanussi ZWF1430W Front Load Washer
Try some WD40 on the machine door mechanism, not on the door; & open/close the door while the machine switch is off, for the mech to become free.
May 11, 2008 | Kenmore Energy Star 44092 Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
129 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
