Question about Nokia N95 Cellular Phone
My screen is upside down N95
My n95's screen has turned upside down and flipped so everything is backwards. it is also please? same problem here. screen is messy, randomly flicking from an 45 ° angle to upside down , randomly turs off the display etc... i just tried the fix written here, but it did not help :(
any other suggestions??
  • Anonymous Jan 23, 2009
    Same Problem on 6102i and screan just went out on my other phone (newer Nokia) I was wondering if it was maybe a software thing or a virus
  • Anonymous Feb 02, 2009
    I had the exact same problem straight after finishing a call. My phone stayed that way all afternoon (turning the screen on and off, flicking it upside down, shifting parts of the image around) before I pulled the battery out and left it all night. After putting the battery in the next day and turning it on, everything was fine. I'm not convinced I've resolved the issue permanently but the phone has been ok since.
    Problem Solver:
  • 18 Answers
Try a firmware (software) update, you can download the NOKIA Software Updater from the NOKIA web site.Do the update even if it is the same SW version that is already on your fone
Posted on Feb 02, 2009
Memory card slot damaged nokia n95
with the help of a toothbrush & petrol clean that one
m sure that ur slot will work
Jan 17, 2010 | Nokia N95 Cellular Phone
Nokia N95 LCD screen goes off/loses power when I slide it open. The screen works fine when closed but not at all when open. Has the ribbon come loose?
The problem with the LCD of your N95 is associated with the flex. This is a common problem to all flip up and slid up phones. I will advice you to take the phone to a technician for proper repair.
Jan 12, 2010 | Nokia N95 Cellular Phone
NOKIA N95 8GB RM17 symatric down load free
due to discunect of strip of Nokia N95 8gb Rm17 pleas provide us strip Shujaat ali C/o Siqlain auto color shop Airport Road GILGIT Pakistan E. Mail
Jan 09, 2010 | Nokia N95 Cellular Phone
My Nokia n95
There are two things that you could do. One is to power cycle the phone and to bring it to the Nokia.
To power cycle it, please follow the steps below:
1. Turn off the phone.
2. Remove the battery, SIM card and the memory card.
3. Leave it for about 5 minutes and then put everything back to the phone.
4. Restart the phone.
If same problem persist, bring it to the Nokia Care Center near you for possible firmware upgrade.
Have a great day!
May 25, 2009 | Nokia N95 Smartphone
Water Damage - Nokia N95
Can you open your n95 by yourself? if yes, detached the LCD then cleand its LCD connector by alighter fluid using a small brush..thank you..
Feb 05, 2009 | Nokia N95 Cellular Phone
Projector displays reverse image also has grayish purple color
Use the remote to go into the menu and change the screen position. There are 4 to choose from, flip left, flip right, flip upside down left, flip upside down right. It may be tricky to navigae the menu backward though.
Dec 31, 2008 | BenQ PB6100 Multimedia Projector
Try the following manual method to hard reset/format Nokia N95:
1) Turn off the mobile device.
2) Turn on the phone and quickly Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button. keep holding the keys untill the mobile phone restarts and prompts you to enter details time and country.
Warning: Make sure the battery is at least 25% capacity so the phone will not power down during hard reset. ( Hard reset normally takes about 2 minutes only).
Warning: Hard reset will format everythings in your phone ( Your contact, calender, photos, installed Apps, Etc.) and the phone will be returned to its original state as if it was purchaced new.
( Mini memory card MMC) will not be effected :)
Dec 06, 2008 | Nokia N95 Cellular Phone
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
2 Press PIC. FLIP to change the
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
4 Press c/d to select the desired
picture flip setting, and press
5 Press MENU to return to the main
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
leave the phone switched on and remove the battery and sim card . leave for 10 seconds then insert the battery with no sim , turn the handset on , after a while when the phone has fully loaded leave it switched on and then remove the battery again , leave for a further 10 seconds and then insert the sim card and the battery when you now turn on the phone you should see the problem has been fixed , if however you are still experiencing the same problems then you will have to contact nokia and get a warranty repair .
May 07, 2008 | Nokia N95 Cellular Phone
in your menu there is a couple of options, one for use with mirror that flips the picture, another that flips the pic for mounting upside down. and another for flipping it upside down with mirror.
please select normal in this option as your prob just mounting it on a desk or table.
good luck
Apr 25, 2008 | LG RU-52SZ51D 52" Rear Projection...
Nokia N95 Cellular Phone Logo
666 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
