Question about Dell Dimension 1100 PC Desktop
COMPUTER DOESN'T RECOGNIZE ADDED MEMORY
I added 256mb ram to my computer for a total of 512mb. when i boot up i get an error message saying i only have 256mb and press F1 to continue or F2 for setup. how do i make it recognize my memory? when i run Crucialscan, it says i have 512mb total memory, but the computer is not recognizing it
  • 4 more comments
  • ssluffman Dec 27, 2008
    when i added memory, i removed the existing card and installed duplicate cards with 256mb each. when i go into setup, it says i have 512mb DDR SDRAM, but i still get a bootup error message that says, "amount of available memory limited to 256mb. what now?
    thank you
    sherie
  • ssluffman Dec 28, 2008
    My computer is a Dell Dimension 1100 desktop. The serial number or service tag number is CQWPJ91.
    If the memory slot was bad, then when I go into setup, wouldn't it not show that i have 512mb DDR SDRAM? I mean it wouldn't see it at all, would it, if either the slot or card were bad?
    It's like it knows it's there, but can't make it available to use....
    thanks for your help!
    sherie
  • ssluffman Jan 07, 2009
    the memory cards were specific to the computer model.
    i found the problem, though, and it wasn't the cards. i made sure that the amount of memory was changed in the setup, but I didn't notice until i was checking the setup again last night, that the OS Install Mode was set to on - it has to be set of OFF for the computer to recognize the new memory. It was an oversight on my part and i fixed it last night - working fine now!
    thanks everyone for your assistance!!
  • przystasm Feb 11, 2009
    I'm not sure what else I can try.
    Today I setup my old Dell Dimension 1100 desktop for my mother I did a fresh XP install and all works well except the pc is not showing or using all the ram that is installed.
    In the PC I have a 1Gig stick and a 256MB stick and in the Bios all the ram shows up, but when I check My System
    with windows it shows 256MB. For troubling shooting I pulled the 256
    stick out and tried the 1Gig unit and it still only shows 256. I tried
    both slots with each stick and no matter what configuration I use all I
    get is 256. The odd thing is the bios shows 1280MB.
    If either
    stick was bad the PC would not have booted. All the bios settings are
    correct, but for some reason I can not get all the ram to show.
    I
    dont have any graphics cards or any other add on's this is a very basic
    unit. It has all the XP updates and drivers installed. When I turn the
    PC on it stays on the Dell
    bootup screen for a good 2 minutes or so, which it did prior to the
    fresh Windows install. I'm wondering if there is something wrong with
    the bios, but at this point I really dont know what else I can do. I
    know all the sticks and slots are good.
    Edit: I forgot to
    mention when I was using the pc about 6 months ago before I got a new
    one all the ram was showing and working. The sticks are 2700 and
    3200..........if that matters and the system can handle 2gigs max
  • VespaMan Mar 28, 2009
    Thanks for your post . We were racking our brains with this same issue, We had upgraded memory from 256Meg to 1Gig and new memoery was not recognized. Got that message to hit F1 to continue or F2 to setup but didn't have a clue what to do about it. Dell didn't help much either, they're chat offfered to fix it for over $100 if we shipped it to them. Anyway thanks again. Its working fine now after changing that simple setting.
  • Hairy_One May 11, 2010
    You have to be a little careful with SDRAM in that later version sticks will only show half its capacity in older mobo. If the stick has an 8Mb refresh block but the mobo only support 4Mb this is the result.
    Were the sticks you used specific to the model of PC or generic.
    Scholar:
  • 91 Answers
Are the memory cards the same? Try swapping the memory cards inside the computer. It is also important to go into the Setup (F2) once the new memory has been added. The setup keeps track of the hardware changes to your computer, and the additional memory needs to be saved in the Setup configuration. Please let me know what happens and thank you. Binary Bob
Posted on Dec 27, 2008
  • Bob Morris
    Bob Morris Dec 27, 2008
    Sherie,
    A couple of things are needed for clarification:
    1. What is the make, model and serial number of your computer?
    2. There is a possiblilty (age-related) that the computer only supports 256MB. (Highly unlikely).
    3. There is a possiblity that a memory slot is bad on the motherboard. You could try swapping the memory around and see if that makes any difference.
    If you could supply the make, model and serial number of your computer, I can find detailed info about your computer. Let me know how I can be of further assistance. Binary Bob
  • Bob Morris
    Bob Morris Dec 28, 2008
    Hi Sherie,
    Verify that the memory speed is the same for both. If the speeds differ, that is probably the problem.
    Some system BIOS (startup program) will recognize the memory installed, even if they don't match.
    CrucialScan is also smart enough to view the memory, but is not able to change the way it works.
    I would take the specs (in Bold and underlined) listed below and look at both memory modules. If the memory module that you added doesn't match, take it back to where you purchased it and request a replacement that matches the specs(speed) for a 256MB memory module. These specs came from Dell based off of the Service Tag number that you provided.
    Technology: DDR SDRAM
    Memory Speed: 400 MHz ( PC3200 )
    Data Integrity Check: Non-ECC
    This is memory upgrades from Dell for your computer:
    Dell
    512 MB Memory Module for Dimension 1100 / Dimension B110 Systems
    Usually Ships Within 24 Hours
    Quantity: 1
    Manufacturer Part# SNPJ0202C/512
    Dell Part# A0735501
    Dell
    1 GB Memory Module for Dell a Dimension 1100 Desktop / Dimension B110 Desktop
    Usually Ships 1-2 weeks
    Quantity: 1
    Manufacturer Part# SNPJ0203C/1G
    Dell Part# A0740397
    Please let me know if this helps and thank you. Binary Bob
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
Poweredge 700 will not recognized memory
Unless only one 256-MB memory module is installed, the modules must be installed in identical pairs. If you want 512MB total, you will need to populate by using two identical 256MB modules or use the same technique for larger memory sticks. That model supports up to 4GB ram of the following type;
PC3200 ECC DDR SDRAM DIMMs
May 21, 2012 | Dell PowerEdge 700 Server
Total amount of RAM not recognized by computer
are the modules the same specs? you may have some incompatibality between them. the board may be reading the ram right it may be you have four 256 sticks instead of 2 of each. read the motherboard manual it might shed some light here.
Jul 13, 2009 | Computers & Internet
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
Sharp Actius AV18 does not recognize added 512MB PC2700 RAM. The machine still only sees 256MB. Is there something else I need to do?
I assume the laptop had originally 256Mb RAM and you put 512Mb RAM in a the spare memory slot and you expected to see 768Mb of memory, is this correct? Try removing the 256Mb memory module and insert the 512Mb memory module and see if the laptop boots up with 512Mb of RAM. If it doesn't boot up then the RAM is either incompatible or faulty. Try using RAM modules from the same manufacturer.
Jun 09, 2009 | Sharp Actius AV18 Notebook
The memory I install to Armada wont boot
You CAN NOT mix 100 and 133 chips! It is not good for the computer. They may let the computer work, but it won't recognize them properly.
If you still want to use the new chips, try and bypass the acklowledgment. Don't know if it is possible, but it may be the only way.
You should be using the correct chips.
You can go to: 4allmemory.com or cruicial.com to find out what sizes your computer is allowed.
Jun 01, 2009 | Compaq Armada E500 Notebook
How do I upgrade memory on a t1100 emachine from 256mb
Your emachines eMachines T1100 only supports modules made with a specific type of chip. Should you find what seems to be the exact same memory elsewhere for a lower price, it is very possible that the cheaper memory will not work in your computer. From what I see you should use straight PC-133 Try a site like Kahlon.com-they make sure it works with your computer as would kingston or corsair...
Your maximum amount of ram is only 256mb total.
hope this helps...good luck- please leave a rating...thank you kindly
Apr 26, 2009 | E-Machines T1100 PC Desktop
Installed a new memory now computer won't boot up.
u just bought the wrong type of memory take the chip out of ur pc to best buy or a good computer store to help u buy the correct memory
Nov 24, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Ram memory Problem?
Go to http://www.memoryx.net and run the 'Identify my computer' bit, clicking on 'Scan my system' and follow instructions.
The other thing is that if the MAX is 512, you'd want low-density memory.
Sep 10, 2008 | Computers & Internet
Dell Dimension 1100 PC Desktop Logo
2,543 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
