Question about iLO 3200 32 in. LCD Television
No color when watching a DVD
I have connected my Panasonic progressive scan DVD player to my 32" iLo LCD TV. While I can see the image from the DVD player but it is not in color. I have tried several sets a cables and even a different DVD player with the same result. How can I correct this problem? Thanks
  • Dennis Campbell Apr 25, 2007
    I appreciate the suggestion but that did not solve my problem.
  • speedbump Jan 11, 2008
    i just moved to anew place andi reconnected my xbox 360 to my tv now when im watching regular tv the color is just fine but when i play my xbox the color is way off i dont know what to do
    Genius:
  • 1,074 Answers
Check your dvd if it is not on PAL if it is then switch it back to NTSC.if that does noe work then call tech to look at your dvd.and tv.good luck
Posted on Apr 22, 2007
I have a Panasoniv 32 inch vivera lcd tv. When I watch a movie the picture looks grainy. Kind of like the pixels are not forming to complete the picture. Am I missing a cable or some kind of compnent for...
If you're watching the movie from a DVD player, make sure all of the cables are fully plugged in and connected. If you're watching the movie from a VHS, it will probably continue to look like that.
Feb 28, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
When playing DVD, image sometimes dark incl. closed caption
1> sometimes supply of low voltage causes some disturbance in trasmitting video signals,it results in darker images while watching.
2> The DVD may have some scratchs or dust-spots or rough-coat on its recording surface ( reflecting LASER beam ) clean DVD and operate again.
3> your DVD player's SMPS (switched mode power supply ) circuitary fails to perform its function properly and giving irregular supply to video-audio card of the DVD player because of having some failure of electronics component housed on this circuitory.
4> switch the mode among 'PAL' , 'NTSC' , 'AUTO' and OTHER in playback mode options ,one by one taking  some minutes.
Now , your problem is solved , Enjoy,Bi.
Nov 29, 2009 | Sony Bravia KDL-32XBR9 32 in. LCD HDTV
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
Tried connecting DVD player to ILO 27 in, no go
go to video on your remote, then go to composite... it should work on composite mode. Took us a while, don't feel bad. Hope that works for you.
Nov 14, 2008 | iLO 3200 32 in. LCD Television
Hooking it up correctly
If you hook up using the tuner in ILO you will lose digital signal to the HDTV (it will still go thru but only as analog) so... Use a splitter from the antenna coax to the "antenna in", then you can hook Ilo output to the tv inputs. You can watch/record analog through the ILO and still switch back digital non recording on HDTV thru its own separate tuner. Hook up the dvd player outputs to the ILO inputs(use the front ones is easiest) and then select SOURCE, pick corresponding inputs and enter. You can watch/record from other dvds that way but not from copyrighted ones, It will say protected content. I would only hook up dvd player temporarily to record from dvd player, then to watch dvd's just hook it up to HDTV. If you can select progressive scan on player to HD it might be even better picture but I don't have HDTV so I'm not sure how that works. Maybe more at this site: http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/ Someone says they are very similar recorders. The front covers are alike i know. Hope this helps.
Aug 18, 2008 | iLO DVDR05 DVD Recorder
Split screen
It appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Jun 23, 2008 | Panasonic DVD-RP56 DVD Player
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
PSCAN shows up on my tv screen when I try to watch movies. How do I delete this?
The solution to the PSCAN! (half screen cut image) is just as suggested, turn off the progressive scan switch in the back of the DVD player to get the full image and enjoy your movie.
Dec 26, 2007 | Memorex MVD2040 DVD Player
iLO 3200 32 in. LCD Television Logo
183 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
