Question about Acer Aspire 3680 Laptop
Battery will not charge nor is able to use AC power to stay on.
Using new AC power cord and will not even turn on until I move and hold the cord in place but cannot let go of cord or will turn off and stop charging. It is an ACER 3680 laptop.
  • 4 more comments
  • Anonymous Dec 29, 2008
    I have the same problem. If I hold it in place, it will charge, but as soon as I let go, it will shut down because the battery didn't charge.I also bought a new adapter thinking that was it and it wasn't. It did the same thing, so I spent money I didn't need to spend.
  • lakeladylore Dec 31, 2008
    I can't get my acer 3680 to boot up at all. It kept blacking out than it would'nt boot up at all, Could it be the batterie dead?
  • rocco_fazzol Dec 31, 2008
    My Acer is doing the same thing. My will not even boot up. The battery light flashes a few times but nothing happens.
  • Anonymous Dec 31, 2008
    I have the same problem i dont know what to do
  • Anonymous Jan 19, 2009
    the computer will not charge even when i try wiggling the cord
  • Anonymous Mar 27, 2009
    My computer will NOT charge. It's not my cord bc my friend has the same exact one and it works fine. I have to get him to charge my battery, so i can use mine. Why won't it charge?
  • 50 Answers
Hi everyone it seems to me that the DC connector is loose inside your laptops,try wiggling it about gently at the charger to laptop cord nearer to the dc socket to verify this.Only solution is resolder or new dc socket.
Posted on Jan 02, 2009
Toshiba satellite c55t wont power on, just blinks once every 4 seconds
check power cord is fully inserted into laptop
if no joy
try also forcing a power down by holding in the power button for 30 seconds and then try power button again to power it up .
might be in hibernate mode !
Dec 04, 2017 | Toshiba Computers & Internet
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
Samsung R480 Will not charge or turn on but indicator lights flash or stay on.
Swap out the ram one at a time testing to see if you can power up, making sure there is one in the memory slot at all times, if this works the piece in your hand is defective, no difference! the motherboard has major issues.
Jul 10, 2012 | Samsung R480 Notebook
My pc battery shows red color when it is on power
If the battery shows a red color and it stays red even when the Power Cord is plugged in, then either the Power Cord is not charging the battery or the battery is completely dead and needs to be replaced.
The battery only has a useful life then it must be replaced because it will not hold a charge.
If you are able to use your laptop with the AC Adapter and Power Cord without any problems then the power cord must be ok and the issue is with your battery.
May 13, 2012 | Dell Latitude D630 Laptop Computer PC...
I have an hp dv2500 and it won't power on. Purchased a new power cord and battery still nothing. Reseeded the hard drive and ram nothing. Tried to power on without the battery and then restart nothing. The...
There's a lot of causes why this has happened in your laptop. Here are some possible causes and solutions to this problem:
Since you bought a new laptop battery, probably it is good and your AC power adapter also, because you said that the power cord light remains on. I think what you mean for the power cord is that it is the AC power adapter.
First, try to power up your laptop through the new laptop battery that you recently bought if you believe it is holding a charge and make sure you don't plug in the AC power adapter into your laptop. But before you turn on the laptop, make sure that the contacts between your laptop battery and your laptop motherboard is making a good connection. Because sometimes it will not, maybe something spilled in there or there's some dust covering the contacts or some sort of dirt and they're not making a clean connection. To be sure that this is not happening to the contacts or your laptop battery and the motherboard of your laptop, pull the battery out, take a toothbrush and just scrub in between the pins of the battery there and also scrub down the the pins where the motherboard connection is (which is the contacts between the battery and your laptop motherboard, where you install the battery). If you are done doing this, put the battery in and turn the laptop on.
If the steps above doesn't solve your problem, try this one:
* Pull the battery out
* Remove main supply
* Hold power button down for 30 seconds. This will drain the charges in your battery.
* Put only power supply in
* Do not put battery in
* Turn laptop on
* Put the battery in
If you're done doing the steps above and did not solve your problem you can try the steps below:
You have to test if there's a fix voltage on your AC power adapter by using a voltmeter, usually 18 to 19V DC depending on the registered voltage written on your AC power adapter. If there is, kinda bend or jiggle the power cord a little bit to make sure the connections is tight. If the voltage remains steady, then probably your AC power adapter is good. Now we have come to the point that we need to deal with your laptop motherboard. There's a lot of reasons why your laptop won't power on even if you have a good laptop battery and AC power adapter. Maybe your laptop motherboard is partially bad, like for example if the dc jack on your laptop is bad and is not making a connection to the motherboard then it might look like the battery is bad as well because the battery is now now holding a charge or even taking a charge. Now this has happened a lot to plenty of laptop owners where their dc jack goes bad. They think their batteries gone bad because is not taking a charge anymore, they got and buy a new battery and then decide to bring their laptop to a laptop repair company because of the battery's not charging even with the new battery, that's because the dc jack is bad. You're going to probably right into this a lot where the battery's not charging because the dc jack is bad and until you fixed that, the battery's never going to charged. So how do you test if your dc jack is bad? It's simple, plug in the AC power adapter, take the battery out of the computer. If the computer doesn't power on then you know you have a problem with the dc jack. The only way to solve this, is that you have to disassemble your laptop, start taking components out one by one and finally, take the laptop motherboard out. Afte you've taken the motherboard out, look where the dc jack is connected. After you will find it, take a file tool and file off a spot on the motherboard where you can reattach the power jack and use a wire to reattach the power jack to the motherboard.
Hope you will find this answer helpful. God bless
http://compunics.blogspot.com/2010/06/podnutz-high-definition-laptop-repair.html
May 14, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Laptop won't a hold charge when plugged in
Remove the Laptops Battery, Plug in AC Adapter... Is it able to Stay Powered On?? Slightly wiggle the Cord Near the plug end while plugged in... Does it still receive true power??? If So, Its Not Your AC Adapter Or Your DC Jack And You should Look into Replacing Your Laptops Battery...
If You Are Not Able To Power THe Laptop Using Just The AC Adapter When The Battery Is Removed, Then You First Need To Check/Test The AC Adapter using A Multimeter To See If You Have A Faulty Cord... If Cord Is Still Getting Correct Power Through To The Plug Tip .. Then You Will Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into on the laptop)
Nov 16, 2009 | Acer Aspire 3680 Laptop
I got an Insprion 2200. It turns on, but once I move it the power cuts out. Not sure if it's the ac jack on the back of my laptop or another internal problem. Even with the battery in there left to charge,...
The DC connect on the system board may be loose. Take hold of it at the connection and wiggle it slightly. If it moves alot, the DC connector on the board is loose.
If not, take your battery out and power up the unit and see it stays on. If it does then it is the battery.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 18, 2009 | Dell Inspiron 2200 Notebook
Problems with charging
This still could be either if the cord is being moved at the same time. when the laptop is able to turn on, Does everything (programs, software, etc) function properly? If yes, then we can narrow it to the battery or ac adapter.
To find out whether it is the ac adapter or battery, take out the battery, and see if the laptop powers up and stay that way. If it intermittently closes or shuts down, it's most likely the ac adapter.
If it stays powered on, even if you move it, then it's most likely a battery issue.
If you want to be sure before spending some money, go to a friend's, neighbor's or computer store with a with the same manufacturer (dell, toshiba, etc), and borrow their ac adapter to check
Nov 21, 2008 | Computers & Internet
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    Computer power
    The power connector on the motherboard is not making contact.
    This is not a simple procedure to correct due to the laptop needing to be completely disassembled to get access to the motherboard.
    If you gently move the power cord around in a circle while pushing towards the laptop it should get power to it until it moves out of place again. Do this while watching the lights panel for any signs of light. Also remember it will take a second or so for the battery charge light to show power entering the laptop, so move the cord very slowly.
    The suggested soloution will invole the laptop being sent to your local laptop repair centre for this to be corrected, or if you still have warranty, then get it done by Toshiba.
    It is also a common fault to all laptops.. There is just not enough strength in the solder that holds the power connector in place to take years of connecting/disconnecting of the cable.
    May 15, 2008 | Toshiba Satellite A135-S4427 Notebook
    Acer Aspire 3680 Laptop Logo
    142 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
