When I turn on the computer it doesn't seem to boot up. I get no video output. And the system beeps. Its will beep for about 6 seconds then pause for 3 and continue to beep again. It also makes a buzzing noise (louder than normal) that appears to be coming from the rear fan, but I',m not sure if its related. I have tried moving my RAM into different slots but had no results.
SOURCE: Alienware Aurora desktop crashes on bootup
try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
SOURCE: Alienware Aurora Desktop does not boot, has no HD activity
If the activity light on the front of the tower is not glowing than it can be an issue with the power supply of the PC. Try to open the tower and try to reseat the Power supply cables and check.
You can also try to Reseat the RAM (memory) sticks. If you have 2 Memory stick you can just try to boot the pc with the help of one stick and vice versa. If still the issue persist you can try to do a test on the Motherboard. Simply take out the Memory cards and power on the pc . if you hear a beeping noise than the Motherboard is fine and if you dont hear a beeping noise that it is a faulty Motherboard.
SOURCE: Good morning. my pc and
Good Day Ilreleonebia!
You should try cleaning all the fans inside your PC once in a while.
Fans, especially in your video card would spin faster whenever you used the video card performance by playing online games that rely on graphics.
It is very normal. What is not is the annoying sounds you are hearing. It should not be. These sounds is cause by dirt accumulating on your blowers and fans. Just clean and the annoying sounds will go away.
Do you mean that the hinges broke and the screen is no longer attached to the laptop. I googled '
Alienware M11X R2 screen' and one of the first results is a story from PC World which contains:
"Dell will repair broken hinges on any Alienware M11x system for any R1 or R2 customer worldwide regardless of warranty status," wrote Dell's John Blain, in a blog entry on the company's website.
