Question about Samsung RS2630SH Side by Side Refrigerator
Ice tray wont flip
I have a samsung RS2630SH refrigerator and the ice tray wont flip over after it makes the ice. The tray fills up with water and makes the ice but wont flip after that. Please help.
  • fairbury Jan 01, 2009
    I can hit the reset button and get the ice tray to empty but after that it fills up, freezes and then keeps trying to fill it more without dumping. Ends up with a big block of ice in the tray and the water just overflows over the top of the tray and runs down the freezer.
    Bob
  • 700 Answers
Check the very back of the ice maker and see if the piece that holds the rear portion of the ice maker has broken into little pieces causing the tray not to flip. the piece costs around 12 dollars and should be available for the unit that you are talking about. Thanks for using FIxYa and please don't forget to rate the solutions when thru please. Tahks again and have a great 2009!
Posted on Jan 01, 2009
Hi have a rs21dcns samsung can any one tell me how long it take to produce ice cubes fo the first time as the manual is not clear about this, and is there any tips i should know thanks
The first time should be on the average of 20-25 minutes. If your samsung is taking longer than 30 minutes, it indicates there is a problem. Fiscally look in the ice tray and verify the water is in there. If not, check and make sure the water line to the unit is connected and the water is supplied to the line. If the water is in the ice tray, then make sure your fill lever is in the down position. This lever is designed to stop making ice when the ice bin is full. If the lever is up, it will stop making ice.
Jun 26, 2011 | Samsung RS2630SH Side by Side Refrigerator
Samsung Intellect Side by side Refrigerator/Freezer ice maker making ice but not releasing cubes.
Either the icemaker support is broken, DA61-01801A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, DA63-02284B
Good luck,
Vlad
First Choice Appliance
Dec 05, 2010 | Samsung RS2630SH Side by Side Refrigerator
The icemaker of our Samsung side by side refigerator gets full and clogged up frequently and although we can hear the machine churning inside, ice is not dispensed. We have put in a new water filter after...
Either the icemaker support is broken, DA61-01801A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, part number DA63-02284B
Good luck,
Vlad
Aug 17, 2010 | Samsung RS2630SH Side by Side Refrigerator
Not producing ice
Did you by some chance put the ice maker in "vacation" mode. There's a little lever on it that turns it on and off. Check your owners manual - you do still have the manual don't you!
Aug 21, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ice Maker not flipping
May very well be a stripped gear in the drive unit. Unplug ice maker and remove mounting screws. Out of the freezer remove front cover and inspect drive gears for damage. Replacement gears should be available through a dealer for you make and model number.
May 15, 2008 | Samsung RS2630SH Side by Side Refrigerator
Rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Jun 11, 2007 | Samsung RS2630SH Side by Side Refrigerator
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS21DCSV Side By Side Refrigerator
Don't buy another Samsung reffigerator. I won't. I and I will always tell everyone I know the same.
I paid over 1200.000 for my refrigerator in Nov 2006. It has never worked correctly. They have replaced everything on the back three times and it is still not working correctly. Since then the refrigator part is not cooling. Today is Sept 10 2008 and I am going to purchase a new refrigerator. It will never be Samsung again.
Sep 17, 2006 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
377 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
