Question about Samsung LN52A850 52 in. LCD HDTV
Green and purple scrolling lines
I have an LG22LC2D-UB that was purchased installed in January 2008.  Yesterday, we installed a ground in that circuit and the scrolling purple and green lines started today.  We watched a movie on On Demand after watching some other shows which is when the lines started.  We are in the process of switching the tv and cable over to an outlet that was not grounded as I type but I don't think it will work.  I have the Best Buy service plan, should I bring the tv in or at least have the geek squad come inspect the tv? samsung 52" lcd tv but i have green and purple scrolling lines only when the cable is on. when theres a dvd its perfect. i dont know wheather to get a cable tech or a tv tech?
    Top Expert:
  • Samsung Master
  • 76,016 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Mar 27, 2017
lukster
  • 217 Answers
SOURCE: red and green scrolling bars on my tv
probably the cable box, scrolling bars are a clasic sign of this
Posted on Jul 20, 2008
  • 21 Answers
SOURCE: Pink and green lines while watching a movie
if this is only happening on your dvd player, then change the type of cable used to link the tv with the dvd player, if that does not fix it then try another dvd player to make sure it's not the player itself
Posted on Dec 28, 2008
jmgldsmth
  • 2005 Answers
SOURCE: 52" Samsung that the top half of screen goes black.
the HDTV has a heat-related problem check your fans. Do they remove heat? the vertical chips paint the screen from top to middle and, middle to bottom so; your top to middle vertical chip is overheating as is your video chip; that is why you have "glitter" in the back ground. get rid of the heat or, bye,bye TV.
Posted on May 20, 2009
  • 267 Answers
SOURCE: Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Posted on Jun 26, 2009
xCAUSALITYx
  • 210 Answers
SOURCE: vertical black lines in samsung lcd tv
Hardware related, needs an engineer as not a simple fix.
Thanks
Posted on Sep 05, 2009
Green and purple horizontal lines
You will most likely need what is called a scan converter/scaler. It will convert your source signal to the desired signal for you. You can find these online.
Nov 21, 2012 | Mitsubishi Televison & Video
I have green or purple or dark lines scrolling up the screen on my Sanyo 42 inch plasma TV
These lines are often caused by interference. Try putting a filter on the input power plug. Make sure there is nothing near by that can be causing interference, like another monitor or computer, microwave oven, fluorescent light, etc. Make sure all the antenna leads are tight and the converter box well grounded. Is this dish or cable?
Oct 31, 2012 | Televison & Video
I have a Hampton Bay, Glendale 52 inch ceiling fan/light. I've installed ceiling fans in the past and am used to having 4 wires coming out of the unit - black, blue, white and green. There are black,...
green on the fan is for grounding the device, some have only a braided bare cooper line. grounding is a safety essential and all modern UL tested electrical devices will have some means of grounding to the homes grounding circuit (the bare copper line). check the installation instructions for the proper grounding method. Then you might consider having a qualified electrician install your fans.
Jun 11, 2011 | Heating & Cooling
Pink and green diagonal lines rollng across the screen??? panasonic 42" Plasma . Only purchased about 3 years ago - but been used very rarely.
Have you tried lifting the ground on the TV? That set has a grounded (3-prong) plug and sometimes sccrolling lines can be caused by a ground loop in your power lines.Are the green and purple lines very short, like just a few rows of pixels tall, or multiple inches, like 3 - 8 tall?
May 04, 2011 | Panasonic TH-42PZ800U Plasma TV
White and purple flickering vertical lines. No image or sound.
I Hope this helps!
Sony has extended the Warranty for people experiencing picture anomalies due to LCD Panel failure through October 31, 2012.
See here:
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 04, 2010 | Sony KDL-46XBR4 46 in. LCD Television
I need a wiring diagram for my DEH-6000 ub stereo
red - ignition, 12 volts with key turned on
yellow - back-up, 12 volts all the time, even with key off
black - ground
orange - illumination
blue - power antenna or remote turn on for external amplifier
grey - Solid grey is postive front right speaker, grey w/black stripe negative front right speaker
white - solid white is positive front left speaker, white w/ black stripe is negative front left speaker
purple - solid purple is postive rear right speaker, purple w/black stripe is negative rear right speaker
green - solid green is positive rear left speaker, green w/black stripe is negative rear left speaker
You may also have a wire for "mute" which mutes the speakers when you have a phone call or other accessory connected to it. I can not remember off the top of my head what color it is, but most times it is brown. If you have an extra wire I have not listed, that will most likely be the one. Most people never use this wire.
I hope this helps, and if so a FixYa! rating would be appropriate and very much appreciated, after all, it is the only reward we get for helping people like yourself for free.
I would be happy to offer more help if you need it, just reply to the post and I will get back to you as soon as I am able.
Good luck with the installation of your radio,
Dave
Sep 04, 2008 | Car Audio & Video
Purple and green scrolling lines
This may be a mechanical or electronic problem that is dealing with the sync of the colour wheel. There is basicly no colour lock. This may be the replacement of the associated circuit board, or the motor assembly or the colour wheel.
The link below is describing about how DLP technology works. They are relating to a front projection type. With the rear screen type, the basic technology is very much the same for decoding the pictures from the TV signal.
http://www.hometheaterhifi.com/volume_9_1/plus-piano-projector-3-2002.html
Jerry G.
May 02, 2008 | Samsung DLP HL-P5663W 56" TV
Green line
sharp is very aware of the panel and main video processor problems.They should give you no problems on the repair.It sounds most likely you have a main video processor problem.
Mar 13, 2008 | Televison & Video
Scrolling Line Propblem
You have a ground loop problem. Buy an adapter that lifts the round ground prong and poof, clean picture.
P.S. Or fix the grounding. More than likely two different ground potentials between Cable/Sat and house ground.
Feb 18, 2008 | Televison & Video
GREEN AND PURPLE LINES ACROSS THE SCREEN
This is a symptom of the circuit failing.
it will soon be much worse.
You need a tech.
you can verify it is the tv circuit.
remove cable or input another signal such as dvd
bring up the TV' menu. does it have the lines.
Jan 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung LN52A850 52 in. LCD HDTV Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
