Question about M-Audio Mobilepre USB Bus-Powered Preamp and Audio Interface Sound Card
Mobilepre no sending signal to software
I've been using the M-Audio MobilePre unit with Garageband for a couple years going into the 1/4 line in jack with no problems...but ever since I tried using a condenser mic with XLR into the back in line 1 or 2 and phantom power on. I can't get any signal to register in Garageband. I see I'm getting a level on the interface but not in the software. Could it be because I recently updated my driver? I didn't change any other settings.
  • birdstuck Dec 28, 2008
    I've just bought this product and I am finding exactly the same problem. I to am using a condenser mic into the rear XLR sockets but now that I've read this I will try it with a Dynamic mic and Jack Plug set up. There is one difference for me which is that my OS is Vista and I had actually concluded that this was causing the problem as when I loaded the drivers I got a message saying the OS was not supported.
3 Suggested Answers
mrninja
  • 600 Answers
SOURCE: my windows xp wont detect m-audio..im tryin to
under device manager you need to reinstall the drivers and controllers-
Posted on Sep 16, 2009
SOURCE: Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Posted on Apr 08, 2010
Yamaha p120
might have them to close togeather
Jul 23, 2013 | Music
When trying to install the M-audio mobilepre usb with the CD, I get the message is not compatable with my operating system (windows vista). Help! What do I do?
http://www.m-audio.com/index.php?do=support&tab=driver&serie_ID=6&PID=8eb1a9920df341303f81bca7ff458be3&OS=x45#tabs
Go here pick your audio device, then pick your Operating system, then download and install. Hope this helps.
Aug 07, 2010 | M-Audio Mobilepre USB Bus-Powered Preamp...
Mobilepre usb and windows vista are non-compatible
There should be a Vista driver available for your device at the M-Audio support website.
Post your results back here.
Mar 31, 2009 | M-Audio Mobilepre USB Bus-Powered Preamp...
M-Audio Pre USB
I guess your output is leaking and you are recording it again to the track.
Try recording with lower output volume. :)
Mar 16, 2008 | M-Audio Mobilepre USB Bus-Powered Preamp...
Recording Device
Pcs needs drivers, and vista is far from being completely stable..
Disconnect the mobile pre...and go here:
http://www.m-audio.com/index.php?do=support&tab=driver&serie_ID=6&PID=8eb1a9920df341303f81bca7ff458be3&OS=45
then restart and connect.
Rock those beats, and keep me posted.
Dec 11, 2007 | M-Audio Mobilepre USB Bus-Powered Preamp...
Open Questions:
See all M-Audio Mobilepre USB Bus-Powered Preamp and Audio Questions
M-Audio Mobilepre USB Bus-Powered Preamp and Audio Interface Sound Card Logo
107 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
