Question about GE PSI23SGM Side by Side Refrigerator
Remove panel cover to reach the dispenser water line
Hello and Merry Christmas to ya'll. I have a GE SideBySide refrigerator with SS Door panel cover and IceMaker. The water line that runs from the bottom hindge up to the dispenser broke. The stub is to short to fit a snapon. I need to replace the water line from the bottom of the freezer hindge to the water dispenser. I do believe that the best way to do this is to remove the door, remove the ss door panel, remove the dispenser unit to be able to reach this line. Is this the only and best way to go about it? or is there any other way . Any manual or suggestion how to go about this? My GE refrigerator is a PSI23SGMCBS
thanks
Luis
  • 71 Answers
SOURCE: water dispenser line leaking at bottom of freezer
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
Posted on Oct 03, 2009
  • 8 Answers
SOURCE: Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Posted on Oct 22, 2009
SOURCE: I have a GE Profile
I removed the control panel (2 tabs under the front edge) removed the 4 screws holding on the paddle assembly and removed the assembly. The disk is glued on the back( I used super glue). If it happens in the future I would try to glue it on without removing everything. If you use a mirror you can see the detent where the disk mounts to the paddle and glue it back on. The disks function is to push on the switch that is located behind a gray rubber panel behind the paddle.
Posted on Sep 27, 2010
  • 2699 Answers
SOURCE: Bottom hinge on GE side
there should be a disconnect behind the kickplate under the door,also a disconnect for the wire harness too.don't cut anything,i've found people cut the wires and then had to replace the door for this.if for some reason there isn't a disconnect there remove the hose from the water valve but there's a disconnect there.pop off the kickplate and you should see it
Posted on Jan 22, 2011
imufo2
  • 3773 Answers
SOURCE: Hello, I have a GE
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 10, 2011
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE SS Side by Side Refrigerator is not dispensing water; makes ice just fine. Is this a problem that I can fix without a service call?
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , to help keep this from happening again , if , the water line is frozen . Pt # WR49X10173 .
BB ..... refrigerators are not your AoE .
Dec 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE sidebyside, I have no water coming out of the dispenser. I did change the filter. I can hear the water sensor come on/orr when I push the handle (dispenser that engages the ice/water).
If determining the water line is frozen , there is a water dispensor heater kit , which comes with installation instructions , pt # WR49X10173 .
Nov 09, 2009 | GE GSS25JEMWW Side by Side
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser on GE side by side profile refrigerator doesn't work
check to see it the resevevouir tank is frozen up inside of the refrigerator, alspo check the the holse ruunning thru thre left door may be kinked. or the wter solenoid may have stopped working . Hope that one of these works out for you. Thanks for using FixYa and have a Merry Christmas!!
Dec 24, 2008 | GE GSS20IEP Side by Side Refrigerator
We accidently left the freezer door open during the entire night and now icemaker doesn't dispense on monogram refrigerator, even though ice maker makes ice.
you might want to turn the whole fridge off (remove the food to a safe place) and let the fridge defrost, wipe any water up and retry. If it is under warranty, call GE
Nov 26, 2008 | GE Monogram ZDI15C Automatic Icemaker
Whirlpool sidebyside
  • take off the door,
  • remove the inside panel (screws under door seal)
  • dig out insulation until you reach water line
  • install a repair union
  • fill up the empty space with spray foam insulation
  • reassemble when the insulation dries.
Jul 06, 2008 | Whirlpool GS6NBEXR Side by Side...
General electric refridgerator won't despense water in the door
Have the same thing happen a few times. The posted solution is correct, but in the mean time you can thaw the line by heating with a blow dryer inside and outside the door, and around the ice dispenser. This should take about 15 mins.
Jun 03, 2008 | Refrigerators
GE PSI23SGM Side by Side Refrigerator Logo
119 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
