Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Warm refrigerator/freezer fan works but unit is not cooling
  • 4 more comments
  • notechskills Nov 24, 2007
    Kenmore side by side model 5350 warm both sides. Was making a high pitched noise, then a faint click.
  • k-anne Mar 17, 2008
    The unit is not blowing cold air. We removed the front cover and cleaned the grille. It was filthy. Then plugged the unit back in. It made a click so we turned it back off. The unit is only 3.5 years old!
  • Anonymous Nov 01, 2008
    I have a 4 years old refrigerator. It only blow warm air.
  • nel21 Nov 01, 2008
    I have a 4 years old refrigerator. It blows warm air only.
  • bettyboop101 Nov 25, 2008
    coils are freezing but keeping cold no water to ice maker bought new heater still doesn't work neither parts are cold
  • soeler Dec 14, 2008
    Had the same problem with my Kenmore refrigerator (was not cooling anymore); came to this site - solution #2 by dwester was exactly what I needed. Compressor relay was broken; bought replacement part for $48 (had to go to specialty parts store). Wasn't exactly the same as the original, but was still relatively simple to replace. The freezer is now working perfectly. Thanks!
Unplug refrigerator, take off bottom cover in back (cardboard). On side of compressor (big round and black) is an electrical component called a compressor relay. Use a screwdriver to pry the entire block off the side of the compressor. Shake the block. If you hear it sound like a rattle, you need to replace it. Bring it to a refrigerator/appliance supply and get a new one. If yours is the original, the new part will look a little different, but just follow the directions. Trust me I just went through this and the part was $45, not $260 like sears was trying to get.
Posted on May 08, 2007
I'm nel21, I posted my problem Nov. 1 2008, and the solution was exactly what Solution #2 by dwester suggested. I spend only $45 and saved wasting over $250. Thank you for your help!
Posted on Nov 09, 2008
Freezer is warm on top two shelves but is still cold on bottom shelf and there is moisture in the refrigerator
Posted on May 22, 2008
Freezer works but refrigerator is not blowing cold air
Posted on Oct 04, 2008
Freezer is building ice when is not supposed to and it feels like it blows warm air on freezer and refrigerator side
Posted on Apr 22, 2008
Freezer frosting up and refrigerator is warm
check the condenser fan in the lower back to make sure its running,if it quits the compressor will cycle on and off to cool itself instead of the fan doing this operation,and the unit will warm up inside,then the compressor will again restart and any condensation in the unit will refreeze and cause frost
Dec 24, 2012 | Whirlpool Refrigerators
Not cooling , fans working
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
67fj
Apr 28, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Refrigerator and freezer are not cool enough. Cleaned coils,has enough space between walls.etc.
Most likely problem is the internal fan. The fan draws air across the cooling coils and blows it into the freezer and refrigerator compartments. If it malfunctions, there's nothing to move the cold air and both sides of the unit get warm.
Nov 20, 2009 | Whirlpool ET1FHTXM Top Freezer...
Upright freezer quit cooling, interior fan runs, compressor runs
The coils are most certainly there probably located under your unit. Clean them thoroughly. Look under and to the very top of that space.
Jul 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Freezer and fridge not cooling well i clean the condenser fan
heatman101
,.f
Mar 13, 2009 | Kenmore 53642 / 53644 Side by Side...
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
823 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
