Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag Stackable W/D
Where is the fuse located? I was about to purchase a timer and then I found this site. My washer won't fill with water, but the spin cycle works. I thought I should try the fuse first. Can you tell where it is located? Thanks
    President:
  • Maytag Master
  • 2,651 Answers
Well htere is a fuse, its located right behind the washers front panel on hte right hand side. its an inline fuse( you can find at hardware or auto part store FUSE (250V 1A) , but this would stop all operations not just water fill. With the front panel off you can "see" through the machine to the filll valve and check it for poower when the "fill" is selected, I would point to a bad water valve or even a faulty prssure switch( not allowing power to the valve befoer condeming the timer.. the pressure switch is also located on the front rail by the fuse assembly anbd will have a plastic'rubber tube connected to it, i would disconnect and blow through the tube for possible obstruction.. ( if the pressure switch is satisified., the machine will think there is wate rin the machine and therfore wont allow anymore to enter.
Posted on Dec 28, 2008
Maytag lse7804ade
Buy the right size fuse. Too big of a fuse can cause a fire.
Aug 23, 2014 | Maytag Washing Machines
MAYTAG STACKABLE WASHER FILLS BUT NOTHING ELSE
In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to our Website where we have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/modelnumbers.htm Once you have the updated information, please reply to this email. Eric Campion
Nov 05, 2013 | Maytag Stackable Washer Dryer
I have a model lse7806ace maytag stackable washer/dryer unit. Initially, the washer would not do anything. I replaced the lid switch and it then filled and agitated at the same time... but when it went...
Ok , when you pull out the washer knob to start it the water fills . Can you stop the filling by pushing the knob in? if so the water valve is ok.
There is a sensing tube from the tub which connects to the pressure switch. This is what causes the water level pressure switch to shut off at the correct level. I would suspect this as they replaced the pressure switch and it keeps filling. If this is the case there is a small hole which will cause the pressure switch not to turn off the fill valves.
You can check this by removing the tube and submerging it in some water then blow in the tube while blocking the other end , if you see bubbles it is leaking and needs replacing.Hope this helps
Feb 19, 2011 | Maytag LSE7806A Top Load Stacked...
I have a Maytag lsg7804aae stackable unit. The problem I am having is that the washer will not agitate or fill with water, however the unit will work on the spin cycle in all modes. Opened front panel of...
timer is good, if you tried it on all the different cycles, must be the water inlet valve, does the hot water work, if you set to warm or hot..if so the cold water valve is shot
Dec 19, 2010 | Maytag LSE7806A Top Load Stacked...
I have a stackable Maytag. The water will not
I had a similar problem I just fixed. There is a fuse inside that keeps the water from filling if it's blown. Might try changing that first.
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Water problem with stackable Maytag Neptune
You have to make sure your self if water is getting through the hoses first.Remove the hot& cold hoses on the back of unit.Make sure there isn't a clog in side of the water valve screens ,if so clean them.Still not filling?Possibly a blown fuse.
Feb 09, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
121 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
