Question about Whirlpool GHW9400 Front Load Washer
Whirlpool duet 9400 Washer won't do anything?
Machine has power control lock light light willl operate. Ran fine yesterday. no erro codes displayed Safety switches on door and soap try working.
  • tazbob Dec 27, 2008
    please help main dial just blinks
    everything lights up
    doeesn`t do anything else
    thanx bob
  • Whirlpool Master
  • 19,396 Answers
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Posted on Feb 22, 2010
  • Ginko
    Ginko Feb 26, 2010
    body {
    background: #FFFFFF;
    margin: 0px;
    padding: 4px;
    font-family: arial, verdana, sans-serif;
    font-size: 10pt;
    p {
    margin:0px;
    padding:0px;
    .spwrap
    background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom;
    Sorry, blind link.
    Here
    the article: My Whirlpool is control locked.
Control locked light is on, washer won't work
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
Apr 05, 2013 | Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool front loading duet washer stops at the rinse/spin cycle door then locks. code F31 comes up. would this have something to do with the main board?
Hello
Error F31 in your whirlpool duet washer is displayed due to MCU (Motor Control Unit) failure. It is displayed if the heat sink gets too hot and then the MCU stops motor, then MCU sends the signal to CCU (Central control unit). Please check the wire connections between the CCU and MCU, if thats fine then check the motor operation. Hope you understand...replacing the part# that has gone bad is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet sport will not work
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer. It worked fine
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%^^%%
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sportwon't respond after power outage
IF YOUR MACHINE IS A WHIRLPOOL DUET TRY THIS ;
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Good luck
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
721 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
