Question about Homelite 'Yard Broom' Leaf Blower
Homelite yard blower won't start
My leaf blower started fine one day, and the next day it won't start. I tried changing the spark plug but that hasn't helped.
  • 2 more comments
  • davdiacody Jan 10, 2009
    My yard broom worked last time-3 weeks ago but won't start now. It is not getting any spark. I took it to a repair shop that wanted $100 to repair it by putting on a new coil. Not worth the expense. My blower is only two years old and used very little. Again...not firing and must be completely disassembled to get to replace coil including the handle assembly and recoil. Any suggestions?
  • Anonymous Feb 08, 2009
    My leaf blower want start. It is doesn't have any spark.
  • Anonymous Mar 14, 2014
    replaced spark plug, but still no spark
  • Anonymous Mar 15, 2014
    I have an echo leaf blower that is not sparking now when I hook the spark tester to the lead and earth it out on the fins of the motor it sparks fine but when I put it on the end of the plug no spark and I have tried 4 new spark plugs
    Scholar:
  • 76 Answers
1st how old is the gas and 2nd how long did it sit for since you last used it? If there was any old fuel left in before now (more than 14 days) than it is possible your carb needs cleaning. If it's less than 14 days then you might want to check the compression. IF you have good compression, then you might want to take it to a service center to have it diagnosed.
Posted on Dec 28, 2008
  • 4 Answers
Just take carb apart and clean it with carb spray 20 min`s and $2 later it will run
Posted on Feb 13, 2009
2 Suggested Answers
SOURCE: leaf blower
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
Posted on Nov 04, 2008
My craftsman 25cc leaf blower wont start
pull the plug, plug into wire, touch head of plug to metal on engine. hold by rubber boot while touching pull starter, see if you get a spark across the plug gap, its small but you can see it. if no spark check switch. if plenty of spark clean fuel system and check primer
Nov 04, 2014 | Garden
125bt starts fine but once shut off will not restart for hours. always used proper gas oil mix. new spark plug runs fine next day
overheating add more oil pull muffler look at piston if scared up bad run till it locks up buy new one
Aug 19, 2014 | Garden
Homelite26b ran one day and will not start the next day I have changed the spark plug and bulb
Dump the fuel and mix up a fresh batch with some fuel system cleaner in it. You may have a partially blocked fuel passage.
If a system cleaning doesnt work check the fuel lines for damage. Many times the fuel line in the gas tank splits and you only get fuel when the level is above the break!
Be safe and good luck!
Jun 30, 2014 | Homelite 'Yard Broom' Leaf Blower
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
My homelite yard broom is hard to start and stay running
check the scrren inside the carb to see if it is ditry or needs replacing.
Jul 16, 2012 | Homelite 'Yard Broom' Leaf Blower
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
Homelite 'Yard Broom' Leaf Blower Logo
3,472 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
