Question about Pride Used Mobility Jet 3 Power Wheel Chair
Battery charger will work - Pride Used Mobility Jet 3 Power Wheel Chair
  • 3 more comments
  • memawdah Dec 29, 2008
    yes we have measured the output voltage. we have also replaced batteries
    sorry for the delay. with the charger plugged in i had voltage going
    in but no dc voltage coming out.
  • captdburchfi Feb 22, 2009
    My father has a used chair that i purchased a few months ago. I replaced the bateries in it and it seemed to work fine, but the batteries will notcharge, when you first plug in the power cordthe onboardmeter jumps to about 6 then goes back to zero. It is possiable t put one of the float battery chargers on it liek used for a boat?
  • Dan Hudson May 11, 2010
    And was the voltage between 25 and 30 VDC? Did you also measure this at the batteries while charging? If so, this is the normal charging voltage. If you have it at the charger, the charger unit is OK, and you need to check your wiring. If you have it at your batteries, then the problem is something other than charging.
    Exactly how do you know that its not working? Have you measured the output voltage?
  • 118 Answers
You will need to replace the charger. I can order one for you, but I need your serial number to be sure to get the correct one. Pride has a one year warranty for parts. Contact me privately via my email: D*H*u*d*s*o*n at G*M*a*i*l dot com.
Posted on Dec 29, 2008
Got new batteries but chRger won't charge them
Battery CHARGERS must have the correct batteries (NiCd or NiMH), plugged into a working outlet, and the batteries much be in a specific position. IF 2 batteries are in a 4 battery charger, and they are both in the center, It won't work. If 2 batteries in a 4 battery charger on the left, it will work if they are both securely positioned.
Once in awhile you get a non-working charger. Make sure you have the right charger with batteries. A few have a switch for NiCd or NIMH.
Jun 03, 2016 | Golf
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
What volt charger do i need to charg mower 12volt battery?
Doug, Any 12 volt automotive charger will work for your lawn tractor, the cheaper no frills chargers will work fine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Battery Chargers Canadian Tire
Amazon com Battery Chargers Jump Starters Battery Chargers Portable Power...
Car Battery Chargers
Feb 27, 2016 | Cub Cadet Garden
12v battery charge doesn't work in car
A few reasons why the charger is not charging the battery: The charger itself is not working; The battery will not take a charge, the battery can be 'dead'. If you can, connect the charger to another battery, just to see if it is working. The charge indicator needle will move. If you have confirmed that the charger is working, then the battery may be beyond charging. Make sure the connections from the charger to the battery terminals are tight.
Jun 11, 2014 | Cars & Trucks
Napa charger #85-435 will not charge
He said his battery charger is not working, this has nothing to do with the car not starting or charging? So if anyone can recomend what he needs to do to get his battery charger working would be helpful to him.
Mar 01, 2013 | Cars & Trucks
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
Battery charger on green light when battery flat ,it should be on red also when charger plugged into bike, bike works ok when you take charger out bike stops working
If your bike works when you have the charger connected but doesn't whith the charger disconnected and just the battery then your battery is not charged or you have a bad connection between the battery and ebike.
If the battery charger is showing green then it normally means that charging has stopped charging and there is no current flow to battery. This could be because the battery is fully charged, OR there is an open circuit (broken wire, etc.) between the charger and battery, OR your battery is so flat the voltage is below the low voltage cut-off point of the charger so the charger is not switching on.
You need to check the voltage out of your battery and compare it to the LVC of your charger (should be specified in the user manual), but from what you have described I'd say you need to replace your battery.
Feb 27, 2011 | Electric Bicycle Motor, Bike,electric...
I have a jet ultra3 wheel chair...the batteries went completely dead..I put in new batteries but now it wont charge...book says to call a tech if the batteries ever completely discharge..is there a...
Its unusual for a charger that was working to stop working because you replaced the batteries. Does your chair operate correctly with the new batteries? If so then I would check the connection of the on-board charger at the controller box located in the front base section ahead of the batteries. Trace the cable from the charger to the controller and make sure it didn't come unplugged from the controller. Your red light on the charger would still light up but you would never charge the batteries. Now if you can locate an off board charger (borrow from a friend or neighbor that has one or borrow one from your local provider) plug it in the charger port located under the front of the joystick and see if the batteries will get fully charged that way. If you can't find any cable problems with the on-board charger and the off-board charger charges the batteries then there is a problem with the on-board charger or the charging system through the controller. It would be cheaper to purchase an off-board charger if the borrowed one works than try to replace the on-board charger. Hope this helps
Oct 10, 2010 | Jet 3 Ultra Power Chair
I have a Makita with 2 PA14 batteries and a DC1414F charger. When I turn the charger one the green light flashes once but no other lights show at all when I'm trying to charge my 2 batteries. Neither...
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Aug 08, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Pride Used Mobility Jet 3 Power Wheel Chair Logo
181 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
