Question about GE JES1288SH Convection/Microwave Oven
Microwave stops At firs our Microwave would arc while using popcorn. Then it would arch with a slight buzz noise and a flash of light but no often. Then finally while using popcorn it arch, buzzed and now it does nothing. Im not sure if its the fuse and the wave guide or if its the fuse and the magnatron. Also is it something I can do myself, What do you think and could you be kinda specific. thanks
    Genius:
  • 1,074 Answers
Power supply have tech look at your microwavegood luck.
Posted on Apr 22, 2007
Microwave make loud buzz sound occasionaly, mainly if I try to do popcorn but it does it with other food too
Check your waveguide cover / spatter shield for grease or food particles. It may be arcing.
To help you further (with free advice), I would need to full model number and FCC ID number from the label on / in your microwave.
Contact me directly here.*
* FixYa doesn't always notify us Experts when you follow up online
Jan 28, 2018 | Microwave Ovens
Microwave popping sounds and flashing lights
The magnetron may be arcing, get warm soapy water and remove all food particals from inside of microwave oven until spotless, and check the hood for bare metal.
Mar 18, 2012 | Hamilton Beach Microwave Ovens
After about 2 weeks of use, the microwave began to make a horrible buzzing noise from the "box" in the upper right hand corner on the back. It also smelled horrible. It then proceeded to stop working...
Two weeks? This is a warranty problem. The buzzing noise was probably either from high-voltage arcing or an overloaded transformer trying to drive a shorted component. The smell is from something electrical getting fried. Remember it; the next time you smell it, you'll know to pull the plug.
Oct 12, 2010 | Sunbeam SMW777 Microwave Oven
Panasonic Microwave NNSD277B 5yrs old makes noise after 20sec on (bUzzing and popping)and internal light flashes. Should be replaced or fixed ? what could be the problem?
You should have no arcing within the unit. Assuming you have adequate food/water in the cavity, it should not arc. You NEVER run the unit without something to be heated in it!!!
You might check the stirrer fan which is often in the roof of the unit to see if contamination might be in the area causing arcing. The electric fields in th area are very high and arcs can jump.
If the insulating window is charred or has charred grease, it should bbe replaced.
Dec 26, 2009 | Panasonic Microwave Ovens
Arcing and noise when turn it on
I cleaned the microwave really well. I used a screwdriver to pull the plastic cover out enough to clean behind the edges with a soft toothbrush. Seems to have corrected the problem.
Oct 15, 2009 | Whirlpool MT4155SP Microwave Oven
Problem with GE Microwave Model JES1358WK 02
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
q
May 30, 2009 | GE JES1358 Microwave Oven
Kenmore 721.80524500 makes a buzzing, grinding noise
Your problem is due to the "magnetron" arcing to the wave guide within the microwave. Picture someone arc-welding stuff together inside the microwave casing, that's essentially what's happening. It is a fire hazard and you should stop using the microwave immediately. As far as I know, there isn't a recall on that particular model (though there was on another similar Kenmore/Whirlpool model) so if it's out of warranty, you're out of luck.
Sep 08, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Buzzing noise and flashing
Some units have a silica plate covering the waveguide opening. If it get burn spots on it, it'll do that. Remove the plate and try the unit. If it's OK, go to your MW repair shop and order a new plate.
Remember... always cover your food...
Geno
Mar 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
GE JES1288SH Convection/Microwave Oven Logo
144 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
