Question about Compaq Presario Notebook
Missing or corrupted file C:\windows\himem.sys
I have a laptop on which I run 98 and when I start it the logo appears and then after a while it says the following file is missing or corrupted:C:windowshimem.sys.How do I fix this missing or corrupted file?
    Scholar:
  • 172 Answers
This file is part of a batch file used in the boot up process of win 98 and Me. You can can search for a copy of the file in your pc by starting in DOS mode. To do this press F8 before the pc boots and select start in dos prompt. When you at the c:\prompt type in.... type sys.ini then press enter, see if himem.sys is part of the displayed text.Failing this do this:
To determine this, boot from a known good bootable floppy diskette. If you are able to successfully boot from a bootable diskette, it is likely the copy of the himem.sys on the hard disk drive is corrupt or missing or not setup properly in the config.sys.
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
hope this helps?
compdoctor2005@btinternet.com
Posted on Dec 27, 2008
  • 565 Answers
or
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
  • Teet Bergmann Dec 27, 2008
    if its helpful rate fixya
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
My netbook will not start up,it says,file is missing or corrupt
it means your notebook missing system file ( Windows file ) , so you must start repair it , and repair progress will bring and set this missing windows file
so you have to press start repair and follow the steps to fix this issue or you can fix this issue with windows CD, just boot your notebook with Windows CD , and after boot start choose repair windows.
last thing you can try this ,
    • press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start, and then press F8.
  1. On the Advanced Boot Options screen, use the arrow keys to highlight Last Known Good Configuration, and then press ENTER.
    i can help you with live help if you want this
Mar 23, 2013 | ASUS Eee 4G Notebook
After installing some recent windows updates, I then did a restart to the computer. The computer no longer will boot into windows. It ' boots to windows xp logo and then changes to a blue screen after...
This may help.
http://www.user-guides.co.uk/cddownload/Samsung/N120-12GBK/Samsung-N120-12GBK-Fix-Repair-NTLDR-Missing-Corrupt-or-Compressed-Boot-Disk-CD-98-XP-2000-502214.html
I have never used one as I have my own boot disc.
Feb 15, 2011 | Samsung N120-12GBK Netbook
I am having trouble running setup on my desktop
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
Aug 28, 2009 | Computers & Internet
Corrupted Registry in Win98SE + Cannot fix.
Try this. Been a long time since I used a command prompt but it should work. If you can get to the boot menu use a start up floppy.
Restoring a Backup
Reboot your computer, press F8 to enter Windows Boot options. Start your computer with Command Prompt ONLY.
To restore your most recent backup.
At the command prompt type --> scanreg /restore and hit enter.
To choose a backup to restore.
Go to the \Windows\Command directory.
Run SCANREG /restore
Select which one you want to restore.
May 21, 2009 | Microsoft Windows 98 Second Edition for PC
Pci.sys
ya you can transfer that file but it is difficult as usual... you need to some dos and using this dos windows you can copied that file into your c: drive...
but i suggest try to repair with any xp cd
Mar 30, 2009 | Toshiba Satellite 4300 Notebook
ThinkPad A21m won't boot into Windows
Did the laptop you got come at least with a windows XP cd? If so boot the laptop off of that and try to install Windows XP and see if it goes thru. Just make sure during the installation you tell it to delete the partitions first and then let it go thru that way you know for sure the hard drive is clean at that point.
Feb 02, 2009 | IBM ThinkPad A21m 2628 Notebook
My pavilion 4445 computer will not boot up .it has error messages that say registry or configuration error. or cannot find win.com. it says to choose command prompt only and run scanrec.but,it wont let me...
It sounds like maybe some malware got into your computer and messed up Win 98 really bad. If you have the OEM disc try and re-install the OS. But you will probably find that Win 98 will not have all the drivers for your computer. It always came up short in that department. And you will find very little on line support for Win 98. It's been obsolete for years. It sounds like this would be a good time to migrate to a more modern OS. Go online and Google Linux. You can get a number of Linux based operating systems for FREE! Ubuntu is supposed to be a good one. It may take a little time to learn to use it but I feel for the price it is worth the effort. Over the years it has become more user friendly. It has it's own applications and should have all the drivers for your hardware. It also is not vulnerable to all of the Windows malware that is out there. So for someone on a tight budget it seems like a good option. While this is not a solution to your immediate problem it is something to consider.
Jan 10, 2009 | Computers & Internet
Win 98 se file trouble
get hold of a win 98 boot disc (search the net) as it will have the files you are looking for, i am sure. copy them to your hard disc c:\windows or c:\windows\system
put them in both as i cant remember what one they go in. (it will not hurt in both).
good luck
Terry
Mar 26, 2008 | Computers & Internet
Compaq Presario Notebook Logo
304 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
