Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony CRT TV audio and video flickers after warm-up period
TV works immediately for 2-3 minutes then picture and sound together go in and out. Has worked perfectly since purchased new in 1991. No previous repairs.
  • greenman3333 Mar 27, 2009
    Sony rinitron 27" picture is perfect then fades to snow and snaps back to perfect picture again. It just keeps repeating over and over. The sound cracks when it goes to snow then back to perfect when the picture is fine. I have a 32" trinitron with power problems as well. It seems these tv's are destin for problems at some point. I will never buy another one after this.
4 Suggested Answers
CompuGuy44
  • 432 Answers
SOURCE: Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Posted on Jul 04, 2007
jerryg50
  • 1689 Answers
SOURCE: Sony triniton 28" crt tv i have got sound but no picture
Any set can be repaired it is the question of the cost and the availability of the parts.
The fuzzy lines with static noise is probably from an arcing in the high voltage multiplier or in the flyback windinngs. I am very sure that the flyback assembly with the high voltage multiplier, and most likely the horizontal output transistor will have to be changed just to start. It is also possible that there may be some failure in the power supply as well.
The set would have to be serviced by an experienced TV tech. As for the cost, it will be a bit expensive.
Jerry G.
Posted on Apr 20, 2008
jingjao
  • 252 Answers
SOURCE: No picture, sound works on Sony TV KV-27V22.
try to adjust the screen. it is located behind the CRT board.(CRT board is the board that attached to the picture tube) you will find a black knob which label screen adjust it by turning the knob.
Posted on Jul 04, 2009
Sony pfm-42x1 flickering screen when turning tv on
OKAY I found the Problem!! Bad Caps Compositors. I Proved this in 2 ways. First I took off the Back(always make sure the TV is UNPLUG) In the photo above I put my finger on the capacitors. I found some that where NOT FLAT ON TOP(You can kinda see in the photo too). I could feel a little nipple on top.(Some times you can see if their busted open but not in this case) so I felt them and the bottom right and top left area in red in the photo where not flat. I took my dryer(My wife really) and warmed them up for about 2 minuets each then another minuet rotating back then forth. I leaned the t.v. up to lean on the frame and plug it in. I continued warming the capacitors up and in about 2 Min the T.V. has stop blinking. Much better then the 20-30 min. So the hunt for the Capacitors is on. It will be some work to get the boards out. If everything is done delicately The Soldor job is easy for me. I am going to buy the 8 but replace 1 board at a time until the TV works and put the other on the side for next time or put them up on E-bay. I hope this helped Please like if this helped you. ea0a96a3-fb82-4ec0-89f4-76b4080e9c6e.jpg 1b190ebd-5d69-4553-a009-840d29ab4c87.jpg ab9b51d0-6e1d-4cce-b822-e80d0fde9163.jpg
Oct 13, 2013 | Sony PFM-42X1 Plasma TV
I have a Toshiba 36"
Resolders the FBT-(flyback tranformer).Resolders the video board connections sockets holes,that the board connected to the CRT-(tv tube).Plug in the tv,to have power to the tv,take out the tv video board,for exposer of the CRT-(tv tube).Take an electrical wire with a good insalation in it,grounded to the tv steel frame some where.Take the other end of the wire go toward the open high voltage CRT-(tv tube).U will hear a pop sound,than ur tv CRT-(tv tube) is a 100% clean out of contaminations or u will hear a deeing sounds only,mean the tv CRT-(tv tube) it is to old to pop anymore,just let tv deeing sounds going on for like about 20 mins to rejuvenated the old CRT-(tv tube).After this repluging the tv video board for a tv signal and readjust the button on the FBT-(flyback tranformer) that said focus to fix the CRT-(tv tube) focus problems.
May 01, 2011 | Toshiba 36A40 36" TV
My CRT TV displays a single horizontal white line across the screen. It will flicker and try to display the picture. If you smack it you'll get a quick picture then back to a line. After about 10-15...
The single line means that the vertical deflection doesn't work. And since it is working when you kick the tv or has warmed it's clearly a bad connection - open the case and reseat the wires going to the tube coil.
Dec 21, 2009 | Toshiba 32A33 32" TV
Sony tv model KV32S42 picture taking forever to come in
Speaking as a retired SONY dealer, the short answer is probably yes. There are some repairs an authorized SONY repair center can do but if the tube is displaying a soft picture, it may not be wise to spend a couple hundred on repairs when a new medium quality TV is three hundred to five hundred for a SONY. I applaud your devotion to a set that has served you well.
Dec 05, 2009 | Televison & Video
Video flashes off and on.
the tuner module is bad.
where the cable goes in in the back of the set,there is 2 modules on the main pc board and they are soldered in.
the smaller block is the IF module and it has broken grounds inside. it has to be removed from the main pc board and there is 7 pins or so.once the module is out,remove the tin covers and resolder the grounds around the perimeter.put the module back in.
i have fixed 100 of them
May 13, 2009 | Sony KV-27V26 27" TV
Sony hd 55 inch tv-picture blacks out periodically, sound is ok.
The component board may be going out depending on what style type TV it is.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/benjamin_494963e790f97efb
Nov 01, 2017 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony TV Repair
crt going bad it is a common problem on sony old sets
Aug 06, 2008 | Televison & Video
Flickering picture
Can you please check the model number, what is listed is not valid for a Sony. This could be a simple fix or something expensive. With the model number, I can provide you with details.
Thanks,
Dan
Apr 16, 2008 | Televison & Video
The tv works however the picture dissapears/ flickers off but comes right back immediately...happens constantly
Picture tube ( CRT ) is defective = re-juvenation may help for
a temporary fix...................................T.
Mar 28, 2008 | Sony KV-35S45 35" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
150 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
