Question about Linksys Wireless-G Broadband Router
Blue wire not fitting in modem
I recently bought a Nultra range plus Router,but i cannot fit the blue wire into the modem.i have dell desktop comp. blue wire male piece is to big. any suggestion.. store i bought from says i'll need to buy hardware for desktop to fit piece in... thks bill
    Problem Solver:
  • 5 Answers
I assume that you are trying to plug the cat 5 cable into the pc and thats where you say its to big. The port your'e trying to plug it into is likely the modem but its not the modem that you want to connect it to. You want to plug it into the network jack on the pc. The modem connection is smaller than the network connection. Most newer pc's come with it already installed, but if you have an older pc that doesnt have a network card then you will need to add one. Take a good look and see if there is another jack that it will fit into.
Posted on Dec 28, 2008
Dell precision 309 blue screen pci.sys eror
Remove any hardware you have fitted recently. Then try again. If you haven't fitted anything recently (this includes USB sticks) then you will need to try the computer in "Safe Mode" )press "F8" when you start the computer.
Sep 06, 2013 | Dell Computers & Internet
I have a dell 2400 desktop computer. I recently got FIOS and they hooked my wife's computer to their router with an ethernet cable. Can I also hook my dell up the same way?
Depends on the hardware. Is it a router or modem? Does is have extra ports in the back,
Router with extra ports, just connect new device with wire or even wireless if it has wireless.
Modem, most likey you have to buy a router.
Dec 28, 2012 | Dell Dimension 2400 PC Desktop
Cant access internet via router on gx280 dell using ehternet cable, I have installed ethernet controller is there some setting i have to set up
if you are able to browse the internet using a modem and not using a router then the issue is not with the comp.., try using a different cable which has a different arrangement of the wires inside.., it will work..,.
Mar 03, 2010 | Dell OptiPlex GX280 PC Desktop
Cant connect old comp to new router
go to > control panel >network connections > in left hand pane.under Network Tasks..click..Create A New Connection... that will start a wizard and will guide you thru the process. you will also need to install the drivers as well for his computer to be able to use the modem/router.
i hope this has helped
Sep 09, 2009 | HP Pavilion a330n (Refurbished)...
Two computers on router, one slows
Try switching the ports on the router, just one computer with the other. If the same computer gets seniority. Try to delete the network connection and make a new one on the slower one. If there is still a problem you might have picked up some spy-ware that is slowing it down. You could also try restoring computer to an earlier date. If you have XP or Vista it is easy.
Mar 14, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hooking up a Linksys dual range router to a 2 Wire cable modem
ok once your internet is resolved you shouldnt need to have any computer hard wired to the router but it should go like this cable from your wall to the modem, then cable from modem to the router, after that you can go wireless all the way just make sure that its all secure and encrypted dont want the next door neighbor stealin your internet
Feb 25, 2009 | Linksys Ultra RangePlus Wireless Routr...
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
I had to move everything and now i can not find where do i plug it into.....the linkseys blue wire with the clear plug in....where does it plug into
I'm assuming you mean the internet wires... The one from the wall goes into the modem provided by your ISP (internet service provider) (should be the slot at the very bottom).. :
A) From there, if you have a router, one must go from the modem to the "modem" input on your router.. From there, plug in the cord in either slot 1,2,3,4 and connect it to the back of your computer (it will only fit in one slot).
B) If you do not have a router, just plug the other cord into the top of the modem, and then connect that to the back of the computer.
Apr 08, 2008 | Computers & Internet
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Linksys Wireless-G Broadband Router Logo
37 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
