1 speaker not working new ones
Just got new insignia speakers for my desktop and only 1 works just a dud pair or something I'm not doing?
  • 3 Answers
Hello is it the first speaker hooked to the computer or the second that is wired to the the first not working, check the wire's it is a stereo plug and if you can try another wire.
Posted on Dec 28, 2008
How do i pair my phone to play on my insignia speaker?
1. Press and hold the button to put the speaker in "Pairing/Connecting" mode. You should see a red and blue light flashing in rapid succession somewhere on the speaker.
2. Turn on Bluetooth on the phone and tap on Scan. The phone will start scanning for nearby Bluetooth devices. When you see that it detected a device with a name similar to the speaker's name, tap on the name to pair with the phone. If you are asked for a passcode/passkey, enter '0000' or '1234' (without the quotes). If the two pair, the light on the speaker will turn to a steady blue and you will see 'Connect' on the phone. Tap on Connect and then you will see Connected on the phone. Your phone and the speaker are now connected.
The steps above should be detailed in the set up guide that came with the speaker. There may even be a passkey/code provided in the guide. Use that one for pairing instead of the passkey I suggested above. Please note that pairing is a one-time procedure, required only the first time you are connecting the phone to the speaker, a "get to know you" procedure. After that, you just need to connect the two.
Nov 15, 2014 | Insignia NS-BT400 Portable MP3 Speaker w/...
How do I connect the bluetooth on a marshall stanmore bluetooth speaker?
Check if you have the correct icon, or look on the web for help.
Nov 04, 2014 | Marshall Stanmore Bluetooth Speaker
How to open Insignia Model:NS-E2111 speaker not working
remove front cover and unlach bottom to get accses to speakers .
Sep 04, 2014 | Insignia Set Of 4 Indoor/outdoor Speakers,...
Speaker not working
Do the speakers need a power source? Maybe an AC plug?
Aug 13, 2013 | Dell OptiPlex GX520 PC Desktop
How to pair craig cma3532bt
To Pair:
1. Turn on your Bluetooth speaker/headphones (slide switch to BT)
2. Light should turn on Blue. If not, plug speaker into USB connector and light will turn Red to indicate it's charging.
3. Make sure Bluetooth is turned on your PC or Phone. Select device name: CMA3532BT.
4. Enter pairing code (passcode): 0000 or you can try: 1234
Jan 03, 2013 | Radio Communications
No sound to speakers
This is pretty easy to troubleshoot. First plug something else into the speakers to make sure they work. (cd player, phone, gameboy ect.). If the speakers don't come on make sure they are getting power. There should be a light on the speakers to varify they are getting power. If the speakers do work when you plugged them into something else, plug them back into the computer and make sure you are plugging them in the right portal. A common mistake is plugging them into the mic jack. Look for a small pair of head phones next to the jack on the back of the computer. Plug them in and go to your volume control on the bottom right of your computer screen. Turn that up. This should fix you problem...if not, you may have an issue with your computer.
Feb 24, 2012 | Insignia Audio Players & Recorders
Do these speakers work better with an amp? I am playing them now and they sound muffled using a regular shelf system
No models given, so a guess is what you get.
If your shelf system is not producing sufficient clean audio power you'll get distortion, which can kill a speaker faster than excessive clean power. Muffling is something else altogether. Are the tweeters working?
Feb 05, 2011 | Insignia 6-1/2" Bass-Reflex Bookshelf...
Need to get brackets for insignia outdoor speakers
Please call Insignia Product Support at 1-877-467-4289 for additional assistance with parts and support for this product.
Feb 19, 2010 | Insignia Simulated Rock Outdoor Speakers...
Lost almost all sound in both speakers
Test the speakers on a bench if possible with a different receiver and some new wire. Or if you have a multimeter check the impedance, should be 8ohms if it's got a short, it will read 1..... or ....1 If the speaker wire when connected to the outdoor speaker is not siliconed, it acts as a wic and will oxidize the wiring and cause a short. do you have a separate volume control for them? and is that volume control indoor or outdoor? is it connected to a receiver or amplifier? The fastest test though would be to hook up the rock spkrs directly to another unit. If you still have trouble, reply and I will help you troubleshoot further. Hope this helps
May 24, 2009 | Insignia Simulated Rock Outdoor Speakers...
KDC 128 CD Player
It could be that the player is going into protect mode. This is normally due to a short in a speaker cable, or one or more of your speakers is blown. Try disconnecting all of your speaker cables at the speaker end and make sure the connectors don't touch. Power it up again and see if it stays on. Bear in mind you won't hear anything. If it powers up. Carefully plug each speaker back in. It will power off if you plug in the dud! If it still doesn't power up. disconnect all of your speaker cables at the player end. If it powers up this time one of your cables is shorted. Same as the speakers, plug one pair of wires in at a time to find the dud. If it's still switching off. It could be a blown circuit on the output stage of the amp. Here's a silly question. Does the player get hot? All this assumes that you have had this player working with these cables and speakers before. If not check that the speakers are the correct rating (Resistance in Ohms) for the player. And lastly here's where you can get a manual http://www.kenwoodusa.com/Support/Car_Files/#_
Sep 09, 2007 | Kenwood KDC-128 CD Player
42 people viewed this question
 Grubhead
Grubhead
