How do I delete an icon from my desktop when I get an error message that says "cannot delete file: cannot read from the source file or disk"?
  • 827 Answers
Hi Barry,
Right-click on the file icon and in menu select "Open with..". Select Notepad as program to use.. It should return the following error.. "This file does not exist......would you like to create a new one?". Click on "Yes" and you'll get a blank Notepad screen, type some text and then save the data.. You now have a working file with data in it which you can delete.
Hope this helps
Chris (ziraffa)
Posted on Dec 27, 2008
  • chris grams
    chris grams Dec 27, 2008
    Ok Barry,
    it would have been easier to diagnose if you had posted what kind of file icon or shortcut it is, what is says under Properties, anything.. I can't even diagnose whether or not it is a spyware problem from your description. But I shall give you another option.
    Well it's saying that because it's target is no longer there. If you go to the target folder and create a text file and call it the same name as the target and save it as that, it'll have a source that it can recognise, then you'll be able to delete it. If the folder is not there, you'll have to create that too.. just make sure the path in Properties exists.
    If you think it might be a spyware issue, then download and run Spybot, search and destroy, fix selected problems and immunize.
    In future, rate such suggestions as Thanks for Trying instead of Inappropriate. The people spending their time trying to fix your problem need to maintain a rating percentage.
    Good Luck
    Chris (ziraffa)
Trying to rename a file in Computer-user-(moms)
Try and download " Long Path Tool " is also useful in situations where you see these error messages: Cannot read from source file or disk, there has been a sharing violation, cannot delete file or folder, the file name you specified is not valid or too long, the source or destination file may be in use and many other file managing errors.
Jul 20, 2012 | Computers & Internet
All Problems have ONE solution and that is: Path too long....
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 25, 2010 | Computers & Internet
This sounds like you've got one of three things happening:
1 - Your USB cable is dying slowly. Over time connections become seperated within the cable. This causes data loss and all sorts of funny errors. Try a different cable and see if that helps.
2 - Your USB plug is malfunctioning or underpowered. If you are attempting to use a USB 2.0 device on a 1.1 connection, errors may prevent you from doing what you want to do. Try a different USB port, see if that helps.
3 - Your MP3 player has a setting somewhere locking files to the device itself. If windows tries to delete a locked file, you will receive an error. Browse through the manual of your device or the settings on the device itself and see if there's a lock or protection or USB mode somewhere.
Because you're getting the "cannot read from source or disk" error, I am strongly geared towards #1. Get yourself a new cable and see if that doesn't solve the problem.
May 04, 2011 | Audio Players & Recorders
Cannot Copy File:Data error (cyclic redundancy check).
Try to download" Long Path Tool " is also useful in situations where you see these error messages: Cannot read from source file or disk, there has been a sharing violation, cannot delete file or folder, the file name you specified is not valid or too long, the source or destination file may be in use and many other file managing errors.
Dec 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Email attachment
you have to clean your hard drive using norton partition magic 8.0
Jun 10, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Cannot delete file
most times the icon u are trying to delete is in use .
what to do,
1. restart yr system in save mode by pressing the f8 key during booting and then chose the option save mode. or use help from ur system to find out how to start yr system in save mode.
2. tryu deleting the icon again n see what happens.
guess this helps.
Dec 27, 2008 | Dell XPS 210 PC Desktop
Error reading from file c;/program files/nero/nero7/core/nero exe. verify that the file exists &tyhat you can access it. same message 3 times ,cd dvd burner not working ,philipsDVD ;RW drive spd3500cc...
Have you move the file or ever tried to delete them.
Have you create new User Profile on Window and paste the Shortcut icon there? Since it may be a reason why you getting the error messages.
So first locate the correct path to the shortcut and then try to open it.
Sep 17, 2008 | Computers & Internet
Virtue memory is low
I wish you could tune up your PC
Start -> run -> temp -> Ok
Delete all the temp files there
Start->run->%temp% -> ok
Delete all the files there
Start -> run-> prefetch -> ok
Start -> All programs -> Accessories -> System Tools -> Disk Clean up
Put a check on Recycle, temp files, etc and continue
Reboot the computer and see the difference..
Jun 25, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
