Question about Sony KP-46WT510 46" Rear Projection HDTV
My d board for my 57inch sony got soaked with some liquid from the lamp when I was trying to remove it because I needed to replace it. I was wondering where can I can some deals on sony parts.
Try this
http://servicemanuals.vstore.ca/index.php/cName/sony-parts/osCsid/1f06546db96d63f66437b5b4c7ccee99
Posted on Jan 04, 2009
Need to unlock parential control for a sony 57inch projection tv with no remote or 4 digit password
If this model has that the owner manual (google model number with manual if you do not have it) should tell you how to reset the code or remove it)
Failing that Sony Customer service has some pretty sharp people and on the phone will talk you thru the process---usually requires the Sony remote.
Apr 02, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
CAN'T GET THE DRIVER SIDE REAR ROTOR OFF MY 2002 CHRYSLER TOWN AND COUNTRY. HELP
Soak it with Liquid Wrench. Rap it all around with a mallet of block of wood, add more Liquid Wrench at the hub on both sides of the rotor, then wait until tomorrow to try again. The Liquid Wrench may work more quickly and effectively if you place a heat lamp near the rotor. Just be sure it isn't so close it damages the paint or plastic on the vehicle body or ignites the Liquid Wrench fluid.
I assume you've already removed all of the hardware that holds the rotor in place.
Sep 09, 2011 | 2002 Chrysler Town & Country
TV Model: Sony Wega KDF-55E2000 Projection lamp warning is on..and today a light red bar appeared at the top of the screen and light blue on the bottom..is this because the projection lamp needs to be...
Hello
There are two possibilities for this fault with Sony Projection tVs. The first is with the lamp itself. The second one is with the lamp ballast baord. Replace the lamp ballast board first. Because, it there is any internal winding short in the inverter transformar of the ballast board this type of fault can occur. you have to replace the ballast baord along with the new lamp anyway. Therefore, replace the ballast board first. If this help you, there is no need ot replace the lamp. Picture of the ballast included here for you to compare.
gopakumarg43_36.jpg If replacing the ballast dis not help you, change the lamp too. OK.
Aug 31, 2011 | Sony KP-57XBR10 57" Rear Projection...
How do you replace the Projection convergance on a sony 57inch widescreen tv.
you will need to replace both of the STK392-560 convergence ICs then the six pico fuses on the D board will need to be checked and possibly replaced, the G board also has two pico fuses that may need replacement. The SONY Type 1 convergence repair kit is available from www.tvrepairworld.com which fits your model the kit contains the two ICs, with heat sink pastre, the D board picos and the G board picos plus the CD that has step by step instructions for the repair
Aug 10, 2011 | Sony KP-57WS500 57" Rear Projection...
I have a sony kds 60a2020. the lamp sensor light was flashing and no picture. i bought a new lamp and installed it and now all i get is red power light flashing three times. as much as i can tell am ...
A lot of these had problems with the lamp door; you need to remove the door and take a careful look at it edgewise---heat from the lamp can warp the door.
Notice the small plastic peg on the back of the door--when installed it engages a lever which is a safety switch so set cannot be operated with door removed.
If door appears slightly warped what I do is engage the lever (usually tiny and blue in color) and turn the set on.
WARNING: IF SET COMES ON DO NOT LOOK AT LIGHT FROM LAMP DIRECTLY. If set works with lever engaged you need to replace the door (EBAY has sellers with most of them) and DO NOT OPERATE SET WITH DOOR REMOVED OR REPLACE OUTER SHIELD AS HEAT FROM LAMP CAN DAMAGE THAT WITH DOOR REMOVED.
Before you rate this solution let me know if you have questions or what you find; engaging the lever will either rule the door out or confirm it is your problem.
SD TECH
Jul 09, 2011 | Sony KDS-60A2020 60" HDTV
Lamp light is yellow. Replaced bulb still not working1
CHECK AND MAKE SURE THAT THE LAMP DOOR IS SECURE ON THE BACK OF THE TV.
Dec 16, 2010 | Mitsubishi WD-57733 57" HDTV
I have a Sony 57inch rear projection HD TV that when powered on turns green then blue and picture turns off. What could be the reason for this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 25, 2010 | Sony KP-57WS500 57" Rear Projection...
Spilled small amount of liquid on it now it does not work. Looking for possible solution, ie motherboard.
remove the battery open up the notebook then spray rubbing alcohol all over the computer keyboard and, especially where you spilled liquid; really soak it; wait 24 hours for it to dry; and, try to turn it on with the power supply connected
Jun 03, 2009 | Sony VAIO VGN-N250E/W Notebook
How to remove and replace damaged power relays
The relay is soldered onto the circuit board. Unsolder the connections using solder wick. Solder wick is a fine copper braid that soaks up solder as it melts, leaving the connection clean so you can remove the old part. You also need an appropriate soldering iron and solder for electronic work. Rosin-core solder, small diameter, and a 40-watt iron are sufficient.
Once you have the correct replacement part, remove the old one and solder the new one to the circuit board in its place.
Apr 26, 2009 | Sony STR-DE675 Receiver
Soaked
you can,t im sorry to say if you stop at a port send from there or perches a new one ? think it might be wiser as you have nackerd the main board
Jan 20, 2008 | Sony Network Walkman NW-E005 MP3 Player
Sony KP-46WT510 46" Rear Projection HDTV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
