Question about Philips Magnavox 9P6034C 60" Rear Projection Television
My problem that i'm having is the picture tube is gone bad.
The screen shrinks almost like the picture tube has gone bad. Then the once the TV warms up it just comes and goes.
  • Philips Master
  • 3,459 Answers
This is a common problem with this model and a fairly easy fix. You can get parts and a photo instruction guide from www.TvRepairKits.com.
Hope this helps
Posted on Dec 30, 2008
Screen turns green The picture and sound are fine when I turn on the tv. After about thirty seconds the screen turns green and then turns off and the power light blinks.
Sad to say, but that's one of the ways a picture tube can behave when it's gone bad. After it warms up, one of the wire elements in the neck of tube sags and touches something it shouldn't. As a result you're seeing the green screen, and then the set shuts down for safety because of voltage feeding back. The only way to repair the set would be with a new tube, and that's completely uneconomical. You can buy a new 32-inch LCD set now for less than the price of a new tube, not including the labor to install the replacement and get the color alignment (convergence) set up.
Mar 08, 2011 | JVC AV-32F704 32" TV
I have a 36" toshiba with a shrinking picture and is now a thin horizontal line. Can this be repaired and is it costly?
The tube on the tv is gone my friend time to look for another tv unless you want to pay more to fix it which could cost more than the tv . hope this helped
Oct 30, 2009 | Toshiba Televison & Video
The tv comes on but the picture tube has gone bad. at first if i warmed the tv up it eventually came on. the all at once the tube went out completely. i need to find a repair place where i can find an buy...
check tv screen on three colour RED /BLUE /GREEN is prasant but light or contrace is low .
if yes
then
first option is video output voltage 180v dc.canacting capaciter Replace with 10uf/250v dc
second option filament voltage 4.5v ac to up 6.5 v ac
and see pictur qulaty is improw .
theerd option is pictur tube charging 3 cathod
after change tube
see tube find this addrees
Setup Guides, Technical Support, and Instructional Videos :::::
Global Sourcing Solutions & Commerce LLC, DBA
Sadoun Satellite Sales
2747 Westbelt Dr,
Columbus, OHIO 43228, USA
(Map)
Office & Phone Service Hours:
Mon - Fri:
Sat:
Sun:
9AM - 6PM EST
9AM - 4PM EST
Closed
1-888-519-9595
Local: 1-614-529-9560
Fax: 1-614-529-6770
Oct 29, 2009 | RCA F36650 36" TV
Antenea cable in back of tv is loose. When watching tv the picture will get small
The antenna jack may be loose, but that's not your issue. The screen image shrinking is an indicator that the tube is going bad. If this is a plasma or LCD then you have a circuit board issue. Time for a new tv, I'm afraid.
Jun 09, 2009 | Philips Televison & Video
Screen shrinks
opto isolators are bad on the LSB, they are no longer available, But you can get the replacement LSB at the following link
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture from 60" to 19" then gone.
The fluid is a fairly easy replacement. They just need to remove the CRT with the bad fluid and drain the old fluid and clean the CRT and then replace the fluid. The Shrinking is just a Vertical Deflection problem which is also an easy repair. A new Vertical IC and a couple Capacitors. In my shop it would run @ $200.00 to fix both.
Dec 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 60 inch projection tv
you can ask a good tv Technion man, since if it happens to be like that then in coming day u will have to face problems. So since this very common problem which will arise in old tv. Actually the real problem is that, some parts in the board may have become weak or the molded part in the board may have fallen down ,so changing that particular part or molding again may fix that problem. Since i am not an Technion I don't the right terms to help u.I have see this problem in many places and don't worry your picture tube is well and good.
Aug 10, 2007 | Philips 9P5544C 55" Rear Projection...
Sony Trinitron kv32fs16 picture shrinks
You have a bad solder connection in the vertical circuit. This will require you to resolder these bad connections before it blows out the vertical output IC or other parts in the circuit. Do this ASAP before you make a small repair into a large one. If you have no solid state printed circuit board experience, please play it safe and take the set into a pro to do this for you. Good Luck
Jun 28, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Blue Tint
Most likely cause would be a loose solder connection that expands as the set warms up until it no longer makes a connection. You may get the blue to come and go by hitting the side of the cabinet after the set is warmed up awhile. (don't hurt your hand doing this, and don't keep doing it to "fix" the set. The connection will have to be located and repaired). Otherwise, there could be a component going bad, including the blue picture tube.
Nov 21, 2006 | Samsung HCN473W 47" Rear Projection...
Picture is shrinking from the bottom
Hi you have lose solder in yor vertical section have a tech resolder it or that problem will cost you .hope you have already have it remedied.
Nov 14, 2006 | Toshiba 36A40 36" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
