Question about Panasonic PT-44LCX65 Television
Panasonic PT-44LCX65 - all of a sudden will go blank and ten come back on and then it will go blank again - sometimes this goes on for the whole evening - other times only a few times.
  • rokinroj
    rokinroj May 11, 2010
    On the right side of the panel, under the little flap, do you get any lights flashing or solid? If so which lights, what color, and how many flashes? (for example 3 flashes every 5 seconds)
    Novelist:
  • 184 Answers
Intermittent loss of picture is most often brought on by an intermittent lamp or ballast board. When you lose the image, look at the rear of the TV for light coming through the ventilation vents. If you don't see any light, its likely the lamp or ballast. If your lamp has more the 3000 hours on it, replace it regardless of whether its the only defective component. It will fail just when something good is on TV!
michtech
Posted on Feb 13, 2009
My tv have a very typical problem it goes to blank screen but the power is on after few seconds it came back as usual ok. this problem comes down after running more than half an hour constantly.
First make sure you have the latest firmware for your tv by going to Panasonic website. Go to the support part of the site an look for any update in firmware.
Once you have the latest firmware and if the problem persist, try to look for any source of heat close to your tv and eliminate it.
If none of the above works, contact your retailer for a repair, this looks like a overheating problem.
May 07, 2011 | Panasonic PT-44LCX65 Television
Pc selection mode is grayed out. I connect a source but still no joy. How do I reconstitute this mode? panasonic lcd model: PT-44LCX65
Check ur connections again.Select it back to tv mode.See if u get tv signal.If u don't have a tv signal.U have dead signal control board.
Aug 27, 2009 | Panasonic PT-44LCX65 Television
Pt-44lcx65
That seems it might be an issue with your ballast. With time this could cause the picture to go away, discountdashmerchantdotcom
Jul 26, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic tv model pt-44lcx65
Howdy,
The problem is with the EEPROM in the TV that needs to be reprogrammed. But you need to have the proper Correction Tool (LSUQ0100).
I don't think it's available to the public. Call a Service Company, but make sure they have the “Correction Tool”.
Thanks for using FIXYA, big IRISH.
May 27, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 31, 2009 | Panasonic PT-44LCX65 Television
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
PT-44LCX65 Convergence
Look in the service manual for the section on using the adjustment set-screws. (I'm not an expert, but this sounds like what you are looking for.) This section is somewhat toward the back of the manual before the electrical schematics and part explosion pages.
Jun 03, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT-44LCX65 Television Logo
134 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
