Question about Marantz ZS5300 6-Channel Amplifier
Marantz PM4000 amp keeps cutting out
My amp works perfectly but when it starts to reach above average volume it cuts out to mute and will only work when i turn it off and on again before cutting again when reaching that same volume. My speakers and CD player both work prefectly when tested with another amp. Is this repairable?
There is a fairly simple fix to this problem here: http://www.audiotoolers.com/ubbt/ubbthreads.php/topics/5316/Problems_with_Marantz_PM4000_A.html
Posted on Mar 22, 2010
This is a known problem with the Marantz PM4000 amplifier and is present on certain models only. If you contact Marantz, they will repair this for you free of charge if your amp is affected.
Posted on Jul 05, 2007
  • 944 Answers
Ref our live chat: The user manual is here; http://www.marantz.com/pdfs/e_pm4001_man.pdf and your nearest service centre is here; Unit 7 Bentinck Court, Bentinck Road UB7 7RQ West Drayton, Middlesex E-mail : info@sstonline.co.uk Hope this helps :)
Posted on Apr 22, 2007
Pm 7000 marantz cuts out when I turn up the volume. Works well at lower volumes... tried other speakers and no issue? Is there a way to check the receiver itself?
If the device works on other speakers then it is probably working as it should. You need to check if the is an issue with the speakers that cause it to cut out. Make certain they are the right Ohms for the Marantz. Check the connections to them. It could be that a safety device is clicking in to protect them amp due to some overload problem, caused by the speakers themselves. It might even be one speaker that is playing up. Try testing one speaker at a time, by not having the other connected and the balance control only to the one connected.
Dec 27, 2017 | Marantz Audio Players & Recorders
Marantz pm 7200 loudspeakers do not cut off when headphones pugged in
Some amps have a button which you press to mute the speakers when the headphones are plugged in. Sometimes marked "Speakers on off". If it hasn't then a new headphone socket would not be expensive to fit. As long as the amp producers sound I don't see any future problems. The previous owner may have used the headphone socket a lot, and simply wore it out!
Jul 19, 2012 | Marantz Audio Players & Recorders
Hi Strange problem with Marantz pm7001 When ever I turn the volume upto around 1/3 and 1/2 of the way, the amp cuts out and reset it self down to minimum volume. It seems like the amp ins't enough power...
What's probably happening is that the amplifier is shutting down or cutting back the volume as protection from damage. You may have a partial short in the speaker wiring that is not a problem at lower levels, but at higher ones causes the amp to see too low a load. There may a problem with a speaker or crossover component that is breaking down at higher volumes. Or something in the amp's output stage is unable to handle the load.
Test the system with a known good speaker system and length of wire and see if the trouble continues. If it does, you'll know it's the amplifier that needs to be checked. If the test speakers can reach normal volume, you can start checking the wiring and other speakers for the source of the trouble.
Mar 13, 2011 | Marantz Audio Players & Recorders
Mute function on the amp
A couple of questions to try and narrow this down:
1) What is the impedence rating for the speakers?
2) When the unit shuts down, will it recover on its own after a little while or do you need to power cycle it to get it to work again?
3) When the unit shuts down, is it hot?
Possible causes of this behavior:
1) Impedence rating too low causing the amp to work too hard and shutdown.
2) Excessive heat (caused by #1?) will shutdown the unit to prevent damage.
3) Possible intermittant short in the speaker wires somewhere? Loose connection?
A little more investigation will be required to find this. A repair shop would run this unit under load and monitor the outputs for heat and any spikes in the signal that could kick in the protection circuits.
Keep us posted on what you find.
Dan
Jun 07, 2010 | Marantz Audio Players & Recorders
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
ZX700.5 cutting out at 60% volume
I figured out the problem, the front right tweeter wire was pinched behind the mounting bracket. everything is now working perfectly.
Sep 22, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Directv AV1 switch Volume Problem
Did you try all the codes listed. Some work certain functions such as power but not volume. Did the installer leave a phone number where he could be reached other than directv toll free number? Did you receive the same remote as the original. Directv has two remote that are identical in appearance but one is rf capable and the other is infared. The RF remote has backlit keys and is compatible with just about any device.
Aug 03, 2008 | Universal Remote Control DIRECTV Universal...
Marantz pm4000 cuts out at middle volume
Checa las bocinas puede que no soporten la potencia del amplificador y por eso se protege.
Apr 14, 2008 | Audio Players & Recorders
Marantz ZS5300 6-Channel Amplifier Logo
2,606 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
