Question about Insignia IS-LCDTV32 32 in. Television
INSIGNIA NSLCD32 We have the same problem as you with your tv. The menu flashing on and off and the controls frozen. Were you able to get it fixed? If so, what did you do? Thanks for your help.
  • 51 Answers
This sounds a lot like one of the buttons on the side is stuck down. Press each one of the buttons firmly, but not too hard, for several seconds, several times in a row. Do each button in succession, and see if that clears up the problem.
Posted on Jan 03, 2009
How to fix frozen menu controls
Main digital processor board fault. Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 28, 2014 | LG 55 55LW5600 3D LCD TV
Frozen display
hi on the remote control press the i button this should remove the caption, go into the menu on the tv select display setting check the time out hope it helps
regards
shaun
Apr 02, 2014 | Samsung Televison & Video
FROZEN USB MENU
I have konka led tv kl26gt611 local key and remote control not working screen red/green /blue flashing only. how to repairing this folt please help me thanks
Nov 25, 2013 | Konka K2386U 23" TV
Its flashing UC MX-780 and I can;t get it to do anything its frozen and tv can;t be shut off or anything
I'm having the same problem. Screen on remote is flashing URC and MX-780 and I can't get it to stop. The device is frozen. I tried taking out the batteries and putting them back in, but it didn't help.
Oct 19, 2013 | Universal Remote Control Model MX-780
No picture flashing yellow light
please make this test and fix it.God bless you
  • Reset component settings. Usually, the problems you encounter with a Mitsubishi projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Jul 31, 2013 | Mitsubishi WD Televison & Video
No picture,flashing yellow light
follow this steps and fix it. God bless you
Jul 31, 2013 | Mitsubishi Televison & Video
Is my tv digital ready its a 48 inch Toshiba theaterview rear projection hd tv (floor model.) also my convergence is out of wack and I don't have the remote can I manually fix it or am I screwed....
you can search by internet for your remote control
and fix it this problem. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Jul 31, 2013 | Toshiba Televison & Video
AKAI Menu screen wont stop flashing over tv signal
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
May 11, 2017 | Akai PDP42Z5TA 42 in. Plasma Television
TV LIFE FROZEN AND FLASHING AWAY
RCA tv's have lately been having a EPROM chip problem( it controls , power on/off , channel up/down , mute , menu , ect... this is happening to other models as well
you can leave it unplugged for a couple of days and then it might work for a while but it will get worse untill it is repaired
Oct 09, 2008 | RCA TruFlat 27F520T 27" TV
VCR stuck on menu screen
Thank you. I did fix the problem. Reviewed the instruction manual for the Samsung VCR and removed the SAFE reading on the VCR by just holding down the TV-VCR button on the RCA universal remote for several seconds which then released the frozen menu screen. From there I was able to reprogram the TV using the instructions and codes for the RCA universal remote. I still have to reprogram the VCR.
Mar 09, 2008 | RCA Universal Remote Control
Insignia IS-LCDTV32 32 in. Television Logo
114 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
