Question about Breville SK500-XL Stainless Steel Cordless Electric Kettle
Intermittently working when the on switch is flipped, sometimes the kettle comes on and sometimes not.
  • Breville Master
  • 19,396 Answers
That means that there is either a lost contact inside, or a defective switch.
The kettle must be taken apart to fix the problem.
Posted on Dec 27, 2008
Breville one cup filter kettle intermittently switches off before boiling . It will work if I keep the button depressed.
Oxidized or worn thermo-switch contacts.
Or, sometimes old age (kettle!:) or overheating can cause springy contacts to bend out of shape.
Get tech-minded person to open/inspect & renew as required.
Jan 19, 2017 | Breville Kitchen Appliances - Others
Russell hobbs kettle base won't turn on
Just pulled apart a Russell Hobbs Whisper Model 3090 cordless kettle which i have been using every day for a few years.
It was intermittent turning on.
I fixed that problem by bending one of the switch contacts on the inside just a little as it had burned away slightly and was only making contact sometimes.
When I put the bottom back on and tested it I noticed that the water had an electrical smell which was strange as I had never noticed it before.
I then pulled it apart again and noticed that one of the main wires from the switch to the element had the insulation melting so I replaced that wire and now there is no smell in the water.
To confirm the smell I held the old wire and insulation on a flame and that is definitely what the smell was. The smell was travelling UP the tube which takes steam down to the bimetallic strip to turn the kettle off and was contaminating the water in the kettle.
Nov 15, 2013 | Russell Hobbs RHOK3123 Cordless Electric...
Kettle not heating up
First check that the kettle is plugged into the cabinet. Then check if switch, (or red power light) lights up when you flipped the switch back and forth. If it does the problem is inside the kettle.
Contact a Gold Medal dealer for service options, repairing it is the best options as a replacement kettle for that model is very expensive.
http://www.gmpopcorn.com/domestic-dealers.cfm
Sep 07, 2013 | Gold Medal 2001ST Silver Streak Citation...
Aroma AWK-161 Water Kettle not turning on
A power outage happened and all of a sudden Aroma kettle was not turning on. I tried different outlets that I knew worked... nothing. So, problem was certainly the kettle. I gave some good sold raps to the base of the kettle and then some to the base that plugs into wall. Walla! The kettle is now working. I pray it continues. And, from now on I'm unplugging base after each use :)
Jan 15, 2012 | Kitchen Appliances - Others
I DO NOT HAVE COOKING INSTRUCTIONS FOR MY KPM-508 POPCORN POPPER
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
Jun 09, 2011 | Nostalgia Electrics Helman Group KPM-508...
When filled with water & put on to boil it start's boiling as normal then after 10 or 20 secs.the lights inside flicker off and the kettle ceases to boil then the lights flicker back on and boiling...
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
Jun 28, 2010 | Russell Hobbs 14339 Cordless Electric...
When the kettle is switched on, the light comes on...
sounds like the element has died. If it's still under warranty, take it back. If it's not under warranty, contact an electrician or appliance repair person. Unless it's an expensive kettle though, it's probably not worthwhile fixing, as elements can sometimes be as expensive as a new kettle
May 20, 2010 | Kitchen Appliances - Others
Switch has stopped working, kettle will not heat water
Hi Bruce or anyone else that has this problem.
I had this problem too and after pulling the base off I found that the switch was ok but the problem lay with the two bi-metallic thermal overload switches that are connected to the heating element. I managed to reset them both and now the kettle works fine. This can become an issue if you have accidently boiled the kettle dry once in it's life. Best of luck.
Apr 22, 2009 | Breville SK500-XL Stainless Steel Cordless...
Breville SK500-XL Stainless Steel Cordless Electric Kettle Logo
763 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
