Check the capacitors and replace the power components.. if not handy with soldering electronics call Tv repairman as you may need to replace capacitors and possibly mother board .. Tv repairman may charge 75-150 dollars depending on cost of Mother board .. good luck
Its a tiny fan inside the silver cabinet where all the plug in jacks are. It keeps the pc boards in the cabinet cool. Most of the time you can blow out the dust in the fan with canned air. If this doesnt work, you will need to replace it. Partsstore.com carries them. You have to get the exact match since the TV reads the amperage so computer cooling fans wont work.
Power supply board is dead.Know how to solders?Check these capacitors for bulge up or pop open,replaced these capacitors will solved this problems.Or can buy a whole reburbish power suppply board at Shopjimmy.com,Ebay.com for the replacement.
its the problem of the socket where you insert the wire in the tv that is gone loose internally and has to be resoldered.if done it again n again the socket will get completely bent or crack internally .so get it repaired donot remove and reinsert wires again n again it will damage the socket.
If you set up Windows Media Player to autosync to the Clix, then, when you delete songs from the computer (including the wallpaper jpeg), the files also get deleted off the clix. Make sure you have Manual Sync enabled in Windows Media Player (or, more accurately, disable auto-sync).
If auto-sync is already disabled, then you have a good, old-fashioned DB corruption. You can reload the firmware from iRiver's website: http://iriverinc.com/support/ultra/clix2.aspx.
