Question about Tomtom (9K00.005) (636926011532) Mounting Unit, Vehicle Mounting
Mounting tomtom 125 with disk
I have a dodge caravan and need to know how to use the disk to install my new tomtom125. Probably need better instructions than in the book. Any help would be appreciated because i am new to this technology
  • 54 Answers
First ensure that the surface you are mounting to is clean use rubbing alcohol also make sure dis surface and suction cup are cleaned. remove sticker sticker peal from sticker on underside of disc place disc on cleaned dash surface. then place mounting cup onto disk this should hold quite well if not i would recommend getting the hard plastic type velcro and attaching to dis and suction cup that works well for me
Posted on Dec 28, 2008
You need to hold the unit against the glas and turn the dial in the bak clockwise until it seats to the glass
Posted on Dec 29, 2008
Heavier Oil weight for Dodge Caravan
10-30 would be better,the 5-20 is really to thin to work well,the factory used it to get a bit better fuel mileage.Your Dodge probably just needs a a set of valve seals,only a couple hour job.
Jan 10, 2014 | 2007 Dodge Grand Caravan SXT Minivan
How much is pads/oil pan and powe belts and trans mount
30-40 for the pads; 125-175 for pan; 40 belts; and 40-50 for mounts depends on where you shop.
Feb 03, 2010 | 2000 Dodge Caravan
Free instruction on installing a transmission on a 2001 dodge grandcaravan
you better have alot of special tools needed for this job,your holding the engine in from up on top,and removing the carriage from the bottom that hold the engine and transmission up,let alone removing the axles.
Jan 10, 2010 | 2001 Dodge Grand Caravan
How to install front struts for a dodge caravan
the strut mounts on top with three studs and on the bottom with two bolts to the spindle support, you will need a spring compressor to exchange the spring, its a good idea to install new bearing plates, when reassembling make sure the spring plate is lined up properly, get repalcement cam bolts for the bottom and then get the vehicle realigned, while you are it its a good idea to check the ball joints and tie rods for any looseness,
Nov 26, 2009 | 1996 Dodge Caravan
I need to replace the alternator on my wife's 2000 dodge grand caravan sport. How do I go about this?
moz-screenshot.jpgmoz-screenshot-1.jpg Removal & Installation
3.0L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    Negative battery cable Wiper module Accessory drive belt Alternator mounting bolts Alternator harness connectors Alternator
To install:
  1. Install or connect the following:
    Alternator Alternator harness connectors Alternator mounting bolts. Tighten the bolts to 40 ft. lbs. (54 Nm). Accessory drive belt Wiper module Negative battery cable
  2. hope this helps let me know if you need more. dc
Jun 24, 2009 | 2000 Dodge Grand Caravan
No satilite reception
Follow this thread and read what demonfatel has to say about your problem.
http://www.gpsunderground.com/forums/showthread.php?t=8718
Apr 25, 2009 | Tomtom GO 700 GPS Receiver
Led lights do not work on radio/cd player. no station/time displ
Work in car audio for a living. dodge caravan's are notorious for having there cd player's **** out. if the led display is out the built in reducers for the display power supply are more then likely shot. head to a junk yard and pull one out if you want to keep it stock :)
can prob get it from them for about 20 buck's and it will plug right in were the old one did. or you can go after market head unit (125-900$ at any electronic's store) buy a harness (about 18$) and a mounting kit (25$) for the easyist install :)
hope this helped
Mar 04, 2009 | 2002 Dodge Caravan
Ignition Coil A,B,C Primary/Secondary malfunction
Remove the Caravan Ignition Coil Step1 Look under the hood for a distributor. The spark plug wiresmag-glass_10x10.gif connect into the distributor cap. If you don't see a distributor, you may have a model with a distributorless ignition system. Step2 Find the ignition coil. On a Dodge Caravan, the ignition coil is at the back of the intake manifold. Disconnect the negative battery cable to prevent injury while you work. Step3 Determine whether you need to remove the windshield wiper/motor module assembly. This won't be necessary on all models. Step4 Disengage the connector securing the wiring harness connector to the Dodge Caravan ignition coil. Then, disconnect the ignition wire from the ignition coil. Step5 Use a socket set to remove the mounting bolts. There are upper and lower mounting bolts. Separate the ignition coil from the mounting bracket. Install the New Ignition Coil Step1 Insert the new ignition coil. Mount the Dodge Caravan ignition coil to the mounting bracket. Step2 Attach the mounted assembly to the intake manifold. With a Torque wrench, tighten the fasteners securing the ignition coil to the mounting bracket with 96 inch pounds of torque (10 Nm). Step3 Tighten the bolts that secure the intake manifold to the bracket with 115 inch pounds of torque (13 Nm). Step4 Connect the wire harness and any other parts you removed, including the negative battery cable.
Feb 23, 2009 | 1998 Dodge Grand Caravan
I have a tomtom125 and the screen shuts down after 30 seconds and won't come back untill I touch it again?
Don't really know about your model, but try going into change preferances and restore your tt to factory specs. This will delete all your setting but then you can start from scratch.
Hope this helps
Dec 29, 2008 | Tomtom (9K00.005) (636926011532) Mounting...
How to Change, back three plugs on a 2003 Dodge caravan 3.3l
you need to put a ratchet ******** the front of the engine and remove the dog bone engine mount this will allow the engine to be pulled forward with strap and you can reach behind and remove the plugs or you can get them from underneath the van hand tightened with a spark plug socket and wrench if you overtighten they will break
Oct 24, 2008 | 2003 Dodge Caravan
Tomtom (9K00.005) (636926011532) Mounting Unit, Vehicle Mounting Logo
220 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
