Question about Microsoft Windows XP Home Edition
Xp windows explorer delay w/ "open with"
Right clicking ona data file and selecting the command "open with" takes more than a minute to come up with the list of suggested programs.
It used to take 5 seconds.  Any ideas?
  • 2 more comments
  • peter286 Dec 28, 2008
    I use Zone Alarm Security Suite.   Recently upgraded to the latest version 8.0.059.000.  Don't know if this is the problem.  One other item:  Nero 8 Burining ROM now takes a long time to load up.  I re-installed the software, but no change in loadup speed.
  • peter286 Jan 05, 2009
    Thanks for the suggestion and apologies for the delay in response -- holidays, etc....
    I'm afraid the problem is worse than a couple of memory hogs.  When I try to starup in diagnostc mode, I get an error to the effect of "Access denied" & wanting me to log in as sys admin.  Since I am the only user on the system, I AM the sys admin. (for better or worse).  It looks like the installation of XP is munged in some weird way.  In other words, the  will not permit me to boot up in diagnostic mode; the system logs (from Computer/manage) do not function, and I'm hoping I can back up my data before everyting crashes.  Already tried backing up to a previous restore point (several points - none work), but that does not work either.  What good is "system restore" if it cannot override an error situation?!
    Yes, it looks, like a re-install of XP is called for.  I'm an old fan of IBM's OS/2, which could be reinstalled without much hassle.  But then, those were the good old days . . .   :-)
    Thanks for your effort.
  • silkster May 11, 2010
    Have you installed any security/anti-virus apps lately?
    Scholar:
  • 40 Answers
Sounds like you have too many background applications running that intercept right-clicks for their own functionality.
Click Start>Run and type in "msconfig". This runs the configuration utility that shows your startup programs and services. Select the "Diagnostic Startp" option , then click "Apply" and follow the restart instructions. When your system reboots select cancel when asked to restore the settings. Now all those burdensome background running applications that sap your system resources will be eliminated (temporarily) and Windows can run without being dragged down.
Try your issue again. If this time its quick and without the long lags you reported, you'll know that at least one of those startup applications is the culprit. Running msconfig again will allow you to restore the Normal Startup, and the Startup tab will allow you to remove selectively that application that is causing the issue.
One way to identify which one is the culprit is to restart normally (select the Normal Start option in msconfig and reboot) and once back up, do a ctrl-alt-del to bring up the Task Manager. Click the "Processes" tab and then click the heading "Mem Usage". This will sort running processes by how much memory resources they consume.
The memory hogs may not be the one giving you the problem, but it's likely that a heavy consumer is sapping the CPU cycles needed to handle your right-click pop-up menu and run-with selection. Make a note of the top heavy memory users (print a screenshot) and use this list to eliminate any that are also on the startup list back in msconfig.
Don't use the "End Process" button in the Task Manager to simply stop them, as you'll likely stop one that is critical to Windows functionality. Msconfig's Startup list just shows the ones that get started at Windows boot up and can be eliminated without crippling Windows - much safer.
Use your memory hog list to start eliminating, one at a time, the offending applications from the startup list until the issues is resolved. Its a little tedious, but helps clean up your system in the process.
Hope this helps.
Posted on Dec 28, 2008
  • Stephen McGloughlin
    Stephen McGloughlin Jan 05, 2009
    That's more serious than a delay in the right-click pop-up menu. Last time my system started falling apart and locked me out of admin functions I ended up having to rebuild it from the system restore CD. After much work and gigs of downloading (service packs 1 through 3 and all my drivers and updates) I got my system back to a useable state, but at least then it was fast and clean.
    Sorry the initial suggestion didn't help.
How to Remove Shortcut Virus on Windows?
Connect the affected USB drive to your computer. When the files on your USB drive have been changed to shortcuts, your files are actually still there in a hidden location. This process will restore the files so that you can see them again.
  • Do not run any of the shortcuts on the USB drive, or you risk spreading the infection.
Determine the drive letter of the USB drive. You'll need to know the drive letter for the USB drive or memory card that has been affected by the virus. The quickest way to find this is to open the "Computer"/"This PC" window. The drive letter for the USB drive will be listed next to the drive label.
  • Press Win+E to open the window on any version of Windows.
  • Click the Folder button in your taskbar to open the window.
  • Click "Computer" in the Start menu if you're using Windows 7 or Vista.
Open the Command Prompt. You'll be performing the fix using a few quick Command Prompt commands. The process for opening the Command Prompt varies depending on the version of Windows you are using:
  • Any version - Press Win+R and type "cmd" to launch the Command Prompt.
  • Windows 8 and newer - Right-click the Windows button and select "Command Prompt."
  • Windows 7 and older - Open the Start menu and select "Command Prompt."
Type .attrib -h -r -s /s /d X:\*.*and press? Enter. Replace Xwith your USB drive's letter. For example, if your USB drive's letter is E, typeattrib -h -r -s /s /d E:\*.* and press ? Enter.[1]
  • This will unhide the files, remove any read-only attributes, and remove the shortcuts.
  • The process may take a while to complete, depending on how much data is on the USB drive.
Open the unnamed folder created on your USB drive. This folder will contain all of the data that was previously hidden by the infection.
26319209-bxzhjmonsmllydp0qa2riq2g-2-20.jpg Copy the recovered data to a safe location on your computer. This is a temporary location while you finish cleaning the drive. You can create a folder on your desktop to hold the files for now. Just drag the files from your USB drive to whichever folder you choose.
  • It may take a while to copy large amounts of data.
Right-click on your drive in "Computer"/"This PC" and select "Format." This will open the Format window.
  • The formatting process will completely erase the drive, so make sure that you've copied your data off of it first.
Uncheck "Quick Format" and click "Start." Unchecking "Quick Format" will scan for and remove the infection on the USB drive. The format process will likely take a while to complete. 26319209-bxzhjmonsmllydp0qa2riq2g-2-44.jpg
Oct 20, 2016 | Microsoft Computers & Internet
Three users of Outlook 2007 shut down their computer and the next time they turn them on, they get the error message "A data file did not close properly" in Outlook and Outlook check's its...
Are you using any trend micro anti virus? If so, try the following
1. Open your Outlook 2007
2. Click on Tools.
3. Click on Trust center.
4. The Trust center window will pop-up and click on Add-ins on the right part of the screen.
5. Under Manage: COM Add-ins
6. Click on Go.. (Middle bottom part of screen)
7. Uncheck all the Add-ins Exept for TMAS (TMAS is Trend Micro) then Click on OK.
7. Restart your computer.
Or if using a anti virus program and you see that in the "add in" options just substitute.
The following link has some problems and solutions for that event ID you gave.
Click here
Regards,
G33k
May 05, 2011 | Computers & Internet
How can i remove microsoft windows 2000 form a dual boot system
Just start windows XP. Open Explorer go to menu: Tools - Folder Options Select : View Tab Select : Show hidden files and folders Click OK In explorer select C;\ Look for file : boot.ini Open boot.ini for editing (double click) CAREFULLY remove the line which looks like : multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" Close notepad, select SAVE Reboot You will not have the option to start windows 2000 anymore. On your desktop right click: My Computer and choose "manage" Select: Disk Management Select the partition where Windows 2000 was (is) installed. Right click and choose format You can now use this partition to store data and or programs
Feb 01, 2011 | Microsoft Windows XP Professional
I need clear instructions on how to transfer data from Windows XP laptop to Windows 7 desktop by Kingston DT1/2GB
I assume the USB pen is formatted and empty.
Place the Pen in a free USB on your laptop and with Explorer select the file/s you want to copy. Highlight the file names and with "My Computer" open drag the files onto the Pen.
When you have finished, remove the Pen and place it in the Win7 desktop.
Open Explorer on your Desktop and select the files in the Pen. Right hand mouse click on them using the move command and place them on your desktop.
When you have finished you can then make folders to move them into on your Win7 Desktop.
Hope this explains it for you.
Nov 22, 2010 | Computers & Internet
Cannot find map data files
You will need a computer with an SD slot, and running Windows Xp. I tried the following method on a computer running Windows Vista, and it did not work. I tried again on an older Xp machine, and it worked first time.
  1. Put the SD (Map) card in the computer's SD slot.
  2. Open Windows "explore". (RIGHT click on "Start", then select "explore"
  3. Locate your disk on the file menu.
  4. RIGHT click on the map disk
  5. A menu pops up.
  6. At the bottom of the menu, select "properties"
  7. Another menu pops up, with several tabs along the top.
  8. Select the tab that says "tools".
  9. In the "error-checking" section, select "Check Now"
  10. Another menu pops up.
  11. Select the box that says 'Automatically fix file system errors".
  12. Click "Start"
The program will only take a few seconds to run. If it works, you will see the file directories of the SD card display on the "Explore' screen. You can then put the SD card back in the GPS, and see if it works.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Aug 06, 2010 | Computers & Internet
How to disable the right click on my desktop
Follow this Steps to Disable Right Click
Step 1 :
Click on "Start" and select "Run." Type "regedit" into the textbox and hit "OK." This command will open the "Registry Editor" window.
Step 2:
Select "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer."
Step 3:
Open the "Edit" menu and choose "New" then "DWORD Value." A new file will appear on the right side of your screen with the file name highlighted. Type in "NoViewContextMenu" for the new file name.
Step 4: Double click to open and type in "1" into the Value data box. Hit the "OK" button.
Step 5: Close the Registry Editor by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and you have now disabled your right-click feature
Jul 05, 2010 | Microsoft Windows Xp Home Edition Sp2...
GPS CAN NOT FIND MAP DATA FILES
I had a similar problem with a nextar X4-T, which has it's maps on an SD card. If your GPS uses an SD card for it's maps, you can try this:
  5. A menu pops up.
  12. Click "Start"
Good luck.
Apr 17, 2009 | Nextar X3-03 Car GPS Receiver
My excel sheet is not opening
assuming you have Excel sw on your PC.
Assuming you are running XP.
Assuming you can start your Excel and Open any excel file using File/Open within excel.
You must associate Excel file with Excel program in your Windows Explorer.
Fastest way is Browse to any excel file with your Windows explorer (NOT IE)
Right click and select Open with...
Browse to find your Excel MSOffice program
Select Use always to use this program
OK
Dec 28, 2008 | Microsoft Excel 2003 (06503995)
Windowslive messenger not responding keeps coming up error8100030d
Error: 8100030d If you are receving the error code 8100030d when signing into Messenger, do the following: 1. Determine what version of Messenger is installed on the computer, and then upgrade Messenger if it is required: 1.a. Click here to determine the most recent versions of Messenger for each operating system. If you are not running the latest version for your operating system, please install the most updated version. 2. Delete the cache files for Messenger. Follow the steps below based on which version of Messenger you are using: 2.a. For MSN Messenger: 2.a.i. If you are running Windows XP or Windows 2000 click Start, click Run, type cmd , and then click OK to open the command window. 2.a.ii. If you are running Windows 98 or Windows ME, click Start, click Run, type command , and then click OK. 2.a.iii. At the command prompt, type the following commands. After each command line, press ENTER:
cd\
cd %appdata%\microsoft
cd "msn messenger"
del /s listcache.dat 2.b. For Windows Live Messenger: 2.b.i. For Windows XP
  • Right click on the Start button and then click Explore to open Windows Explorer. On the Tools menu, click Folder Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Click to clear the Hide extensions for known file types check box . Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them
C:\Documents and Settings\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts\ Your Messenger email address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
2.b.ii. For Windows Vista
  • Click Start and then click Explore to open Windows Explorer. On the Organize menu, click Folder and Search Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Clear the Hide extensions for known file types check box. Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them.
C:\Users\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Users\ Your Windows logon name \AppData\Local\Microsoft\Windows Live Contacts\ Your Messenger e-mail address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
3. Try to sign in to Messenger again.
Aug 24, 2008 | Computers & Internet
Could not select "show hidden files & folders" in folders option
go to system registry.......click start then run and type regedit then find this key HKEY_ LOCAL_MACHINE software microsoft windows current version explorer advanced folder hidden showall
in your right pane show it DWORD key of CheckedValue delete it.....and create new DWORD key and give the name CheckedValue and enter 1 into value data.......
restart your pc..........
good luck.........
The best earn money site..plz signup free
http://bux.to/?r=jiteshright
(Join now and receive a $0.05 Sign-up Bonus)........click on it........
Jul 30, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Home Edition Logo
256 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
