Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
F7 is beeping constantly...fan is also running
Have under counter stove Jenn Air JJW9530AAB
We had a similar issue. I assume you have the touch pad keyboard. If you clean this with a rug that produces static it will cause a problem with the touch pad. I replaced ours and it is now working again. You can get this part at repairClinic.com. Our p/n for this was
1008902 Touchpad & control panel assembly (Black) 1 $173.10 $173.10
but make sure you check for the correct part/number to fit your oven! Make sure you disconnect power from the oven before you disassemble anything!
I was very happy with the service from repairClinic.com. I can highly recommend using them!
Posted on Jan 03, 2009
Why won't it operate?
Hi Pam, Is this not covered in the user manual? Additionally search online by "error code f7 f1" and see what hits you get.
Jul 10, 2015 | Jenn-Air JJW9630C Expressions Collection...
I have a jen air propane oven and four stove burner and it is flashing a the code f7-1 and saying call a a tech. Please help the beeping is very annoying
Hi, the error code implies that the Function key shorted or stuck..
You need to replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 20, 2010 | Jenn-Air JJW8530C Expressions Collection...
Beeping and F7 when cleaning
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
175 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
