Question about Bronica SQ-A Medium Format Camera
How do I get the spare spool out of my bronica sq-a?
I'm new to medium format so I'm more than likely doing something wrong. But all the manuals I have read just say to lift the spool up and out, pushing up to the right. But Mine wont budge and the little square on the side wont open. What am i doing wrong? Is there something I need to press as I take it out?
5 Suggested Answers
  • 15 Answers
SOURCE: Bronica SQ-Ai shutter problem
There could be a number of issues with this problem. Make sure the contacts at the rear of the lens and those on the body that connect with those on the lens are clean and straight. If so, the problem may be in the shutter within the lens. There is a magnet inside the shutter that sometimes becomes contaminated and fails to hold the shutter blades open for the selected shutter speed. The face of the magnet may need to be cleaned. There are also timing switches that sometimes go bad or need adjusting. These internal problems need to be taken care of by a competent technician since the lens needs to be completely disassembled. I have also seen these shutters go bad and need to be replaced. Let's hope that's not the problem because it will be difficult to get a new shutter for the lens--but not imposible. God luck.
Posted on May 01, 2007
SOURCE: bronica sq-b, mirror lock up lever was broken
Hi, I have the same problem - my lever plastic become broken in 2 days after I'vet body from KEH. Seems that iron topof the lever can be screwed in counter clockwize direction and after new one lever installed it can be screwed back and fixed with rubber cap.
But question to you - where did you get the replacement?
You can contact me on nkir@mail.ru at any time.
Regards,
Kirill.
Posted on Dec 24, 2008
dougbrowng
  • 37 Answers
SOURCE: shutter stays closed on bronica 645 etr medium format
Since the problem occurs with several lenses it is not a shutter problem. Taking a picture, the shutter closes, the mirror comes up, the shutter reopens and closes. Signals from the body cause these actions. It is probably a bad connection or broken wire in the body.
Posted on Jun 23, 2009
cammedic
  • 667 Answers
SOURCE: Bronica SQ A The plastic 'double exposure' lever
I doubt if you will find a suitable material unless you switch to making one out of metal. Brass would be my choice.
Posted on Dec 07, 2009
Non availability of LR 44X4 battery for etrsi
They are still easily available online.
Here's one supplier that I regularly use. Even if the supplier is no use to you, you'll see the many other model numbers for the same battery.
Aug 16, 2011 | Bronica SQ-Ai Medium Format Camera
Camera cocks but will not fire. New batteries
Is there film loaded? Bronica cameras feature an interlock that will prevent the camera from fully firin when not loaded, when no back attached, or when the dark slide is in the back. Some models have a small flip-switch that doubles as a double-exposure switch on the side that can be used to dummy fire the camera to test fire it.
If that doesn't work, consult a tech. The electronic's in these cameras go bad qute often these days.
Jun 15, 2011 | Bronica SQ-Ai Medium Format Camera
Format nokia 6030 mobile
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 1234 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
Mar 07, 2010 | Bronica SQ-Ai Medium Format Camera
Just starting out with medium format. We bought a second hand Bronica SQ-A from a reputable dealer but the shutter will not **** in 'Normal' 'single exposure setting'. Cocks fine in Multi-exposure setting,...
Sounds like a problem with the single/multi "switch".
Film should not wind on in "multi" setting.
Back to the dealer - if he is reputable, he will get it fixed.
Dec 26, 2009 | Bronica SQ-A Medium Format Camera
Film winding handle missing
Depending on where you live, your best bet is one or more of the following: 1) eBay 2) your nearest Tamron distributor/service centre (Tamron bought Bronica in the early '90s and may still cary spare parts). 3) local camera repair centres
Mar 22, 2009 | Bronica SQ-A Medium Format Camera
Bronica sq-b, mirror lock up lever was broken
Regards,
Kirill.
Dec 22, 2008 | Bronica SQ-Ai Medium Format Camera
Shutter not Cocking?
Try removing and re-attaching the lens. IIRC, the actual shutter mechanism is part of the lens assembly
Jun 19, 2017 | Bronica SQ-A Medium Format Camera
Apr 30, 2007 | Bronica SQ-Ai Medium Format Camera
Bronica SQ-A Medium Format Camera Logo
70 people viewed this question
Top Bronica Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Bronica Photography Expert? Answer questions, earn points and help others
