Sanyo 6103051130 Projector Lamp for PLV-HD1 Logo
kelly whitcombe Posted on Apr 22, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a second hand sanyo plv-55wm1 won't come on
Bought this second hand, but don't know much about these projectors and what accessories i should have with it, as when i turn it on the green light flashes for few seconds then stays on green then few seconds later it goes back to red, but the whole time with no picture or anything, the only thing that happens is a fan or something starting up inside. could you tell me if there is something i need to power this up, all i got with it was the ac lead!! please help i paid good money for this and very dissappointed. cheers
  • kelly whitcombe Apr 22, 2007
    thanx for replying, but that doesn't work, what happens is i plug it in, the red power light comes on, then when i press the on/off swoitch the green light flashes 39 times for 15secs then it turns green for 2 secs then goes back to red flashing light, which flashes slowly for 45 secs then the green light comes on flashing rapidly for 10 secs then back to red slow flashes for few mins till eventually stops on solid red, help!!!
Anonymous
Level 3:
  • Master 944 Answers
  • Posted on Apr 22, 2007
Anonymous
Master
Level 3:
Answers
944
Questions
Helped
786904
Points
2417
Sorry couldn't answer you on the live chat. Here is the link to the user manual for your projector; http://sanyoservice.com/pdf/images/PLV55WM1(OM5110720-00_05).pdf Check page 51 - i am pretty sure that the projector is overheating - most likely as a result of needing the filter cleaned - check page 46 for details of how to do this. If this does not solve the problem, just check that there is nothing else blocking the passage of air from the filter to the fan as far as you can tell from the outside, and if still no joy then you need to get hold of a replacement filter, although it is unusual that these cannot be cleaned enough to use (it is not a good idea at all to try and operate the set without one) Hope this helps, if not then please post back with any change to the condition you described and we will see what we can do :)
1helpful
Samsung hln617w won't turn on fans run lamp and temp light go on
2 different brands and models listed here--for the Samsung inspect to see if color wheel is intact and not shattered---have to remove the lamp to see it.
PLV-Z2000 Projector Your question about PLV-Z2000
what about the Projector Condition leds: POWER, WARNING and LAMP REPLACE? How are they lit? For good measure you should also clean the air filter (the projector might not be getting enough air to cool the lamp)
Looking for replacement lamp for Sanyo PLV-WHD1 TV Lamp type # POA-LMP96 service parts # 6103227382. Need some help finding one that is compatible for reasonable price.
You can get replacment lamps for this TV from www.TvRepairKits.com
Models Supported = PLV-55WHD1, PLV-65WHD1, PLV55WHD1, PLV65WHD1 ,PLV-55WR2C, PLV-55WR2CH POALMP96 , POA-LMP96 , 6103227382. and more.
Lamp for PLV-Z2000: Hello , I have a Sanyo Z-2000 projector. Aft...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
1helpful
Sanyo PLV 60 HT keeps on overheating even after I cleaned the
hi dear plz check the projectors fan. It is working properly or not
Sanyo plv70 multimedia projector has yellow rectangle in centre
Either its dust on the mirrors, if so u need to clean then, there are 3 mirrors inside. Or one of the mirrors is bad, then u need to buy a new one. I would recomend you to NOT do that yourself, leave it to someone who knows how to to that.
Good luck
Sanyo PLV-55WM1
Hi I read your problem with the Sanyo PLV-55wm1. It sounds to me like a power supply problem. Like most new electronics devices, they use a switched mode power supply (SMPS)to supply the voltages to the rest of the set. Many of them use a current feedback loop to sense a short in the circuits that it powers. I would check for a shorted diode in the high voltage section of the tv. If any one of the components is shorted around the high voltage circuit, The current control line will be zero forcing the regulator to shut down.
Top Sanyo Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Rob Hill
Rob Hill
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
