Question about Jwin JD-VD141 DVD Player
JWin JD-VD141 Volume / Sound too low
I have a jWIN JD-VD141 DVD player. The volume of the audio is too low. I turn the volume all the way up on the TV and it's just about loud enough to hear well enough to enjoy, but not quite. It should be much louder with the volume turned all the way up.
No volume at all
Posted on Jul 23, 2009
In the DVD remote put more volume that will help a little bit. The DVD has a volume control besides the one from your tv
Posted on Jan 11, 2010
DVD DOES NOT READ DISC
Just check and clean the lens and retry your disc. If nothing change, replace your lens with new one.
Jan 22, 2011 | Jwin JD-VD141 DVD Player
My jwin model jd-vd509 does not play all regions,how can i change that? iwas given player in macau in macau as a gift,but find that the origanal dvd`s i bought in the uk and australia wont play,it comesn...
Don't know if it will work on your. I have a jWin JD-VD141 and the code works. Have the DVD tray open (means ejected) then press 9735. A menu will pop up and choose Regions 0 then exit. You DVD player should play DVD from all regions.
Dec 08, 2009 | Jwin JD-VD509
I have jwin jd-vd503 it does not work it shows
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
  1. (Open the disc tray)
  2. Press SETUP
  3. Press 1, 3, 6, 9
  4. Press LEFT 3 x
  5. Press RIGHT
  6. A new menu entry appears (Version)
  7. Select it and select RC (0=codefree)
Sep 15, 2009 | Jwin JD-VD502 DVD Player
No adio
Picture but no sound is common and there are loads of ways this could happen.
Check red and white cables haven't been swapped and are in the right places in both machines, tv and source. A good way to test is to make sure red cord is in red input on tv and that the correct AV channel is on (ie you have picture) then try each output from source (DVD player, sky, etc). If none give you joy there could be a problem with the AV channel you're using so switch to another, ie change from AV1 to AV2, and then start again.
Jul 23, 2009 | Jwin JD-VD141 DVD Player
I NEED THE REGION FREE CODE FOR JWIN JD-VD-141. THANKS.
With the DVD tray open, press 9735 on remote. A menu will pop up, arrow down to Region, then arrow right to highlight the desired region (0 for all). Press Select, then arrow down to Exit Setup and Select again.
Apr 14, 2009 | Jwin JD-VD141 DVD Player
TV screen is rolling and video appears only in black and white
Somehow we were able to get it fixed ourselves. We pressed the SETUP button on remote, then pressed the DOWN button 4 times then press the RIGHT button, then ENTER button for factory default setting.
Jan 09, 2009 | Jwin JD-VD141 DVD Player
Dvd disc is not recognised after loading
i would like the code for this jd-vd141 dvd player
Oct 09, 2008 | Jwin JD-VD141 DVD Player
Code to configure the Universal Remote for my Jwin DVD player (VD141)
jWIN products do not have a series of uniformed universal remote codes, therefore, they can not be provided at this time.
Aug 03, 2008 | Jwin JD-VD140 DVD Player
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Jwin JD-VD141 DVD Player Logo
477 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
Sheldon Dedek
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
