Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Eco light flashes after one hour of cycle.
I have a hotpoint bfi620 dishwasher,when switch onto full cycle after one hour the machine stops and eco light flashes all the time.
  • jamie_aspina Feb 19, 2009
    Did you repair this fault or use a engineer. Thanks
  • 157 Answers
The heater is faulty.
Posted on Dec 31, 2008
Why does the eco light flash when i set a programme
My Eco light was flashing fast ,and the drain pump was running continuasly.It turned out at the drip tray was full of water and micro switch add activated . i tipped the machine forward drain the water off the machine as be working fine since. PS dont know why drip add so much water in it, unless theres a leak. ???
Mar 05, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Hi there, we have had our dishlex 300 dishwasher switched off for a while and today I turned it on. I started a cycle and it stopped after a few minutes and then the Eco button started flashing. I opened...
Hi just read your posting.Now the reason these dishwashers flash ECO is because there is either water in the bottom tray or your drain pump is open circuit.Is the machine making a pumping noise when it is flashing the ECO light,or is it completely silent?Please reply on additional information and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Dishwashers
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
When I switch on my dishwasher setting it at normal wash cycle it appears to start as normal then after few seconds goes onto to Eco 45 c wash - the light flashes but nothing happens i.e. no water comes...
you may want to check and clear the pump
you have something slowing your drain
but for giggles make sure your float valve is free to go up and down like it should
all dishwashers attempt to drain first
so you have a conflict between the float position and the pump sensor
Oct 08, 2009 | Hotpoint 24 in. FDW60 Free-standing...
The Heavy Duty and the Daily Cycle lights are
to better assist you can you provide me with the ERROR code, if is any.
Thank you
May 15, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
May 23, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Eco light flashing on Global 300
drained out where the float is, haven't run a full cycle yet but a partial cycle worked. i think definitely drain the float tank.
Apr 18, 2008 | Dishwashers
Hotpoint fdw60 eco error code
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
HTH!
Mar 24, 2008 | Dishwashers
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
654 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
