Question about GE WBSE2090A Top Load Washer
Washing machine My washing machine is filling with hot water not cold water. It worked find yesterday.
  • 640 Answers
Check your inlet vavle...check that fill hoses are on proper
Posted on Dec 27, 2008
My washing machine does not fill with water. It was fine yesterday.
You have given very little info about your machine. But with the possibility being a few . I can say . Its probably water inlet valves . Try hot wash . If the hot water flows then its probably your cold water inlet valve.
Apr 24, 2016 | Hoover Washing Machines
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
To fill tub with hot it makes humming noise only, turn to cold to fill tub cold water only
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 31, 2011 | Washing Machines
Why does the hot water work but not cold water
heatman101
Jan 19, 2011 | Maytag Washing Machines
Cold water fill does it heat to temputure requied?
If your washing machine has inlets for both hot and cold water, you should connect both if possible. If you can only connect cold water, the washing machine will still work and heat to the required temperature, but it will need to heat the water in the machine, so the wash cycles will take longer and it will use more energy.
If connecting a hot and cold fill washing machine with cold water only, you will need to connect a Y-Piece for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine.
Please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My Maytag LAT9400 top loading washer has stopped allowing hot water to enter the tub, only cold water works. What might be wrong?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 06, 2010 | Maytag Washing Machines
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Water is not filling up.
turn off water
disconnect fill hose from tap
examine screen inside hose end for 'muck' blockage
clean screen
reconnect hose
test washer
if no fill
replace water solenoid valve
note: cold water valve fails first, it gets most use,
if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is no the cold one and the washer can be used, cold only, for about as long as it has operated thus far..
Oct 14, 2008 | Fisher Paykel EcoSmart GWL15
GE WBSE2090A Top Load Washer Logo
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
