Question about Admiral AW22 Top Load Washer
Vibrates and moves during spin cycle
Recent problem
15 year old machine
operates well other than spin cycles
    Sergeant:
  • 221 Answers
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Posted on Jan 08, 2009
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Washer moves during spin cycle
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
May 27, 2012 | Westinghouse WWS833ES Super Capacity Top...
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Excessive vibration during spin cycle
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
Washer moves during the spin cycle
Due to strong vibration during spinning definitely the machine will stop. All you have to do is to check your load if equally distributed from the tub. To eliminate the vibration and the movement of your washer you need to align the four legs of your washer using level tools. Just put the level on the top of the four sides (front side, left side, right side and backside) then make necessary adjustment if needed on the 4 leg of the washer. Also check the water level of the balancer and the mounting position from the top of the tub.
Jan 31, 2009 | Whirlpool LSR5132PQ Top Load Washer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore 22932 Top load washer has excessive vibration at end of spin cycle
IF THE FLOOR IS NOT ABSOLUTELY STABLE, IT WILL MAGNIFY A SMALL VIBRATION INTO A LARGE ONE. PUT SOMETHING ON THE DRYER IF IT SETS NEXT TO THE WASHER, AND TURN ON THE WASHER INTO SPIN. IF THE ITEM ON THE DRYER SHAKES, THE FLOOR IS MOVING.
IF THE WASHER IS ON CARPET, REMOVE THE CARPET OR CUT HOLES IN IT WHERE THE FEET ARE SO IT IS NOT SETTING ON THE CARPET. THE CARPET AND PAD WILL BE TOO SOFT FOR THE WASHER TO SET STABLE.
ALSO, PICK UP ON THE REAR OF THE WASHER TO RESET THE AUTO LEVELING REAR LEGS. YOU SHOULD HEAR THEM MOVE AND RESET WHEN YOU SET THE WASHER BACK DOWN.
Apr 03, 2008 | Kenmore 22422 Top Load Washer
LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Jan 05, 2008 | Washing Machines
Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Nov 08, 2006 | Maytag MAV4755A Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Admiral AW22 Top Load Washer Logo
235 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
