Question about SmartDisk FlashTrax MP3 Player
"copy" light keeps flashing. Blue Screen. Does not start up.
I have just charged up and tried to reuse my FlashTrax after a couple of years non use. No problem initially. All loaded up properly...but then I entered the "Software Update" set-up by mistake (not connected to a PC) and so stopped the Set-Up. From there the FlashTrax will not work or start up properly. The blue screen (wiwthwhat appears to be a part logo)and "copy" light keep flashing but nothing else happens. I have tried turning the FlashTrax off but the on / off button will not work. I have removed the battery which at least turns it off and it remains off after I replace the battery - but as soon as I turn the FlashTrax back on the same blue screen and "copy" light flashing occurs with the FlashTrax appearing to be corrupted. Please advise. Thanks.
    Problem Solver:
Push the reset button on the bottom .
Posted on Dec 10, 2007
SOURCE:
Blinking battery light
If it has not been charged for a long time, it will probably take a while to start charging.
Aug 28, 2014 | Dell My XPS M2010 Notebook
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
Xenius 37" lcd blue light just keeps flashing
my 37" xenius tv started losing its picture to a stripe screen then started flashing red blue green .know wont come on at all .wht part do i need to fix it please
Aug 07, 2012 | Televison & Video
I have a dell optiplex gx280 and i turn on the computer and it tries to start windows but thengoes to a light blue windows screen and it says that it is checking file system on c. It does a chkdsk and then...
If it looks like this picture, What your seeing is colloquially known as the 'blue screen of death.' It usually means that whatever kind of corruption is in your file system is only repairable through a full format. But first follow these steps:
If you are able to access the BIOS menu (usually holding down either F2 or F12 on startup) try booting in safe mode. If that has no success, try booting from your operating system disc. This problem is common in old computers and is a sign of the end of its life-cycle. Consider purchasing a newer model.
Jul 19, 2011 | Dell OptiPlex GX280 PC Desktop
When I load some mp3 files onto my FlashTrax, they playback fine. Others don't. It's as if the FlashTrax doesn't recognize that they're there. What might be the problem?
Hello
OK, i would firstly advice you to make sure that all the audio files you copy to the unit is actually .mp3 format. If the files is not in .mp3 format, the unit will sometimes give you this error message.
Kind regards
Andrea
Nov 25, 2010 | SmartDisk FlashTrax MP3 Player
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Why does the battery light keep flashing?
The battery is failing to recharge itself.
Contact Dell -- a battery should last longer than that.
Dec 08, 2009 | Dell Latitude D600 Notebook
Unit shows 'loading' continuously
This player is equipped to do a self power on test to all pain parts of the player to assertain everything is ok. The blue light will keep flasing until it completes its task and then the blue light will stop flashing and you you can start reusing it.....................sodeep
Jul 30, 2009 | JVC DR-MH30 DVD Recorder
FlashTrax40GB
hi
try system restore on your pc and restore it to the last time your flashtrax worked ok
Aug 07, 2007 | SmartDisk FlashTrax MP3 Player
SmartDisk FlashTrax MP3 Player Logo
201 people viewed this question
Top SmartDisk Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a SmartDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
