Question about Polar CS100
Hi, i have bought a bike with a polar cs100 computer attached,only for some reason can remove the display unit, please can you assist me on the save removal of the device.as i do not have any instructions. thanks richard
Is it mounted on the handlebar? Try pushing down gently and then twist 90 degrees. It should come away from the bar mount. It attaches the same way in reverse.
Posted on Feb 02, 2009
Download microsoft word 2007
I bought a new computer and installed word 2007, but found that when I do some work it automatically saves. When I want to delete my saved work from word 2007 - there is no remove icon. So I'm stuck with the saved work and all the others are building up in a long list. Also, on my old computer I had no problems with this, I could even click onto email on the top bar of word 2007, and send my word via attachment email. But now this also does not work. The email icon is not displaying properly but is ghostly in appearance. Please help!!! (wayne)
Mar 15, 2011 | Microsoft Computers & Internet
I cannot get the computer to register miles when I hook up the system in my garage ...it's a cs100 polar cycle computer. It just stays at zero when I spin the wheel. I took it off my old bike where it...
The CS100 is designed to only work off the front wheel. if you are using a trainer where the rear wheel is spinning and the front wheel is stationary you will get no reliable reading. if this was the case on the old bike, you got lucky, the system is not designed to read that way. Too far a distance between sensor and computer.
If you are moving the front wheel, as on rollers, and you are not getting a signal than either the sensor and the magnet are not reading each other (too far away from each other, as an example) or the sensor has a dead battery, or you have the bike sensor turned off in your settings.
Jan 08, 2011 | Polar Cycling
I installed replacement batteries with the polarity reversed. Since then unit does not display the Contact file, but all other functions (activities, data files, etc.) seem unimpaired. Any ideas? I...
Hi, well the reason this has happened is that these contacts are stored in battery backed up NVRAM, now this RAM is very sensitive to polarity reversal, and also due to the way it works, doesn't have polarity reversal protection, on that circuit. So when you reversed those batteries even though the reverse polarity protection saved the Unit as a whole, the NVRAM would have been destroyed or wiped at best. These is no real way of replacing this NVRAM, I guess you could send it back to the factory though and ask for a "Quote" with view to the repair.
Sep 14, 2010 | Sharp Zaurus ZR-5700
Battery life poor
Check for cable corosion, and any bad ground or power on.
Dec 17, 2017 | Polar CS100
I have a Schwinn Adventurer ladies bicycle and dismantled the bike last winter to place in my garden shed. I can't find my manual and my son says that something is missing to attach the back wheel onto...
Not without understanding what is missing.
My guess is the Quick-Release skewer for the rear wheel is missing. There is never any reason to actually remove the device from the wheel.
http://www.performancebike.com/images/nashbar/web/PDFs/QUICKREL.PDF
If it's more complicated can't you just take it to a bike shop and ask a mechanic?
May 18, 2010 | Cycling
Just bought a new polar CS100B cycle computer. Installed in on my bike but the speed is not registering at all.
Check the distance and aligment between the magnet on the wheel and the sensor on the fork, if too far it will not works properly.
May 18, 2010 | Polar CS100B Cycling Computer Heart Rate...
Intermittent failure of hr detection
Several issues with the Polar unit, 1 if it is in the cold the unit does not work properly. 2. If your layering yourself the unit will not work properly. 3, If the unit is not place properly on the body and there is not sufficient moisture, the unit will not work properly.
The best that I can suggest is make sure that you have sufficient moisture on your body, hold the polar cs100 near your body till it detects a heartbeat, the place back on the bike.
If your layering do to weather, you may not get it to respond till spring. I know what a waste.
By the way I had the CS 200, and I can't begin to tell you how many of my riding buddies had the same issue that your talking about including me.
The situation with polar rarely has to do with with interference but with a weak transmitter.
Oct 12, 2009 | Polar CS100
Cannot get my new cadence(WIND)sensor to work. will aparently teach. Any ideas
No reactions to any buttons:
Reset the training computer by pressing all the buttons simultaneously for two seconds until the display fills with digits. Press any button and set the time and date in Basic Settings after the reset. All other settings are saved. Skip the rest of the settings by pressing and holding STOP.
Polar Cadence Sensor W.I.N.D.
To activate the cadence sensor in your training computer, select Settings > Features > Shoes/bikes > Bike
1/2/3 > On > Cadence > On.
Teach new sensor? is displayed.
• If your sensor is already taught, select No.
• To teach a new sensor, make sure that there are no other cadence sensors nearby (40 m/131 ft) and then select Yes.
After selecting Yes, Start test drive is displayed. Rotate the crank a few times to activate the sensor.
The flashing red light indicates that the sensor is activated. Completed is displayed after the
teaching has been finished. The training computer is now ready to receive cadence data.
To return to time mode, press and hold the STOP button.
Good Luck,
Techjoel
May 08, 2009 | Polar Cadence Sensor W.I.N.D
My Dell600 won't power on with or without A/C adapter
Hi!
If the unit was a Brand New purchased, and still 4 months old, its better to avail the "warranty" of the unit, to save you from any trouble. But if it is a second hand without any warranty, you can eithertake this risky step or submit it to a certified service center.
The risky step is to open your laptop, and check the "charger terminal" for loose contact, or solder detached terminals.
Dec 31, 2007 | Dell Latitude D600 Notebook
Polar CS100 Logo
281 people viewed this question
Top Polar Cycling Experts
kirkjw
Level 1 Expert
mcgsp
Level 1 Expert
R Daniel Wolfe
Are you a Polar Cycling Expert? Answer questions, earn points and help others
