Question about AEG Lavamat 16810 Front Load Washer/Dryer
AEG LAVAMAT 74620 shows "CE" error
There's a clicking sound from the area of the detergent drawer
I fixed it, but I still don't know for sure what the "CE" error code is. I guess it is for the water distributor. I opened it up. There are some gears in there that move a mechanical arm that distributes the water into different containers. The mechanical arm moves around an axis -- it was very difficult to move, so the gears kept slipping. I opened it, and put some greaze inside. Closing it up was a real pain. But it works, and I didn't have to wait around to receive a new distributor.
Posted on Dec 28, 2008
My AEG Lavamat W1010 will not put the final rinse through the fabric softener section of the dispenser drawer
Hi Cath.
You probably have a faulty Inlet Valve. This is the one which introduces the water through the Softener drawer (As you said)
The other one which seems OK flushes the detergent into the machine.
It may be a double inlet and only the rinse part is faulty.
Not a big job for a Technician
Good luck
Nomess
Jan 29, 2015 | AEG Washing Machines
I need to replace the water pump og AEG Lavamat 74620 (1998)
So do it. there are two. one to recycle and one to exhaust. they are close to each other in the front bottom left hand corner of the casing below the drum and behind the lower front panel that contains the filter and drain. though it's far easier to get at them by removing the thing from situ and taking the back off.
Mar 18, 2013 | AEG Washing Machines
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 74620 shows a Cd error code. Can you tell me what problem this indicates.
CD means door lock is defective. this may be due to the door catch broken or even the main board being defective.
Nov 23, 2010 | AEG Washing Machines
Aeg oko lavamat 72600 update, ce error code showing any idea?
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
My AEG lavamat 74620 doesnt fill up with water
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
May 06, 2009 | AEG Lavamat 72640 Front Load Washer
AEG OKO_LAVAMAT 74620 gave me a code error C7. What is it?
take off the bottom front panel, a booklet is taped to the right side of the panel for the sevice tech it has all the codes
Feb 28, 2009 | AEG Lavamat 72640 Front Load Washer
Detergent drawer does not empty detergent
hi! remove your powder draw, it should just pull out with a wiggle,give it a good clean in hot water, before you put it back give the draw hola a god clean with a bottle brush and hot water! good luck
Dec 20, 2008 | AEG Lavamat W1050 Front Load Washer
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
AEG Lavamat 16810 Front Load Washer/Dryer Logo
629 people viewed this question
Top AEG Washing Machines Experts
shaun taylor
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
