Question about As Seen On TV Clapper Plus
Does not work
I just received a clapper plus. When I try to use it by clapping ,it will turn a light on and then off one time, occasionally twice and then it no longer works. The remote control will not work at all. What do I need to do
Open it up. Insert an ear plug into the hole for the Mic. I got mine to respond to the distinct claps and not be confused by the noise caused by women's shoes forexample... The Radio control works by HOLDING the button for 1 sec not more. Test it with any LAMP.
Posted on Jan 14, 2009
What's clapper
Urban Dictionary: clapper
www.urbandictionary.com/define.php?term=clapper
Urban DictionaryA stripper who is able to make her behind shake so vigorously that the cheeks clap, or the behind that claps.
Clapper: For Your Car - Curbed LAla.curbed.com/archives/2011/01/parking.phpCurbedJan 24, 2011 - Shoppers who have lost track of their vehicle amid a maze of concrete ... What Really Happened at Rustic Canyon's Rumored N Ranch?"The Clapper" for your car - Honda-Techhonda-tech.com/audio-security.../%22-clapper%22-your-car-1068326/... Send a message via AIM to VAAJ. Default Re: "The Clapper" for your car (PHiZ) ... I like the idea... What is the US dollar for that? AU $99.00. Bbasso is offline ...Emoji Quiz Clapper board, Blue car, Oncoming car, Red car ...
Dec 08, 2015 | Cars & Trucks
I plugged a heating system into my clapper and now it is not working. The lights on the clapper don't go on when I clap. I think it glitches out but don't know how to fix it and now I'm really upset. What...
Clappers are only designed to manage less than 500 watts. Heaters are typically much more...greater than 900 watts. You likely burned it out and will need to send it in for replacement. good luck
Feb 01, 2015 | Miscellaneous
Good afternoon, I search a french instructions for Micro Pets tomy "Gork " Serie 2 U.S . I have forget my instructions list :/ Please help me. Thank you
If you have a brand-new MicroPet, remove the"Try Me" plastic strip before using the pet.Turn the MicroPet over and locate the plastic strip protruding from the batterycover; pull the strip straight out.
    • 2
Change the batteriesif the power is running low -- the included batteries are used for testing andmay not be fully charged. Turn the MicroPet over and use a Phillips-headscrewdriver to remove the screw at the top of the battery cover. Slide thebattery cover out and remove the old batteries. Insert two LR44 batteries,making sure to match the polarity as instructed. Replace the battery cover andtighten the screw with the screwdriver.
    • 3
Wake up your MicroPet by pressing the button onits head; it will perform an action to let you know it is awake. Say a phraseto your MicroPet, then wait for its nose or tie to light up. Now say a secondphrase and the MicroPet will follow your command. For example, say,"Robo," then wait for the pet's nose to light up, then say,"Run," and the MicroPet will run.
    • 4
MicroPets display two "moods,""happy" and "bad," depending on the commands it receives.If you repeat the same command over and over, your MicroPet will display a"bad" mood. It will then refuse to listen to your commands and willnot respond to you. Praise yourpetto cheer it up and make it happy. For example, say, "Good job," toyour MicroPet.
    • 5
Press the button on top of the pet's head while itis performing a command to reset the MicroPet.
    • 6
Hold down the button on the top of your MicroPet'shead for three seconds to make it go to sleep; it will sing a goodbye songbefore shutting down.
    • 7
Make your MicroPet sing one of three songs byclapping your hands. Clap three times for "It's a Small World," fourtimes for "Ten Little Indians" and five times for "ElectricalParade." Make sure to wait for the pet's nose to light up between eachclap. Place multiple MicroPets together and they will sing in unison.
    • 8
To program your MicroPet, turn the MicroPet off,then press the button on top of its head six times --- the pet will light up,then make three small beeping noises. Wait one second and the pet will light up--- press the pet's head button now if you want to program the "GoForward" command. To program the "Turn Right" command, wait forthe pet to light up twice, then press the head button. To program the"Turn Left" command, wait for the pet to light up three times, thenpress the head button. When you hear three beeping sounds, the MicroPet isfinished programming and will perform the commands. You can program up to fivecommands in a row. When in program mode, your pet will not respond to your voicecommands or sing songs. To go back to the normal command mode, simply turn theMicroPet off then back on.
Feb 18, 2011 | Tomy Micropets Tomy - Kuda. Magic voice...
When LED lights are plugged in and the clapper is off - some of the lights still glow - not as bright as when on, but still appears as if power is seeping to them (just a little). Help - really wanted to...
There's nothing wrong with your Clapper. LED's have very low current draw - under that which is required by the Clapper to function. You can add a small nightlight to your lights which will up the draw for the Clapper to work properly.
Dec 18, 2010 | As Seen On TV Clapper Plus
My Clapper Plus works fine, except that when it is off, some current still leaks through. I have Christmas tree lights plugged into it. When the Clapper Plus is off, the lights are dim, but are still on.
You obviously have a faulty Clapper. They are supposed to work just like a switch...ON or OFF. If you are getting dim lights, it is bad. Take it back where you got it or call the company.
Thanks for using Fixya.
Wayne
Dec 11, 2010 | As Seen On TV Clapper Plus
My asus eee mini laptop with linux
Hi Clappers
You must go to setting>network>LAN & configure ip & dns then try
Harry
Jun 27, 2009 | ASUS Eee PC 900 Notebook
Clapper goes off every few minutes with no stimulus to do so
While in the Away setting, the clapper will turn on when it detects any noise over a specific threshold. After ten minutes of inactivity, it will turn off. This setting is meant as way turn on the lights as soon as you walk in the door or to startle might be intruders. If you slide the switch to Lo or Hi mode, the clapper will respond to your claps or any loud noises that sound similar. Hi is high sensitivity, for quieter rooms; Lo is low sensitivity, for louder areas.
Jan 27, 2009 | As Seen On TV Clapper Plus
Clapper plus
Sliding the switch down to the HOME (LO) position will put the Clapper Plus into the low sensitivity mode. This is helpful if there is a lot of external noise in the room. By placing the switch in the HOME (HI) position it will put the Clapper Plus into the high sensitivity mode for quiet clappers or if you are far away from the Clapper. In the AWAY mode appliances will turn on with the detection of any sound but will only stay on for 10 minutes.
Dec 06, 2008 | As Seen On TV Clapper Plus
Won't work at all
Check the power at the breaker box. Call in an Electrician if you have to.
May 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
As Seen On TV Clapper Plus Logo
754 people viewed this question
Top As Seen On TV Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you an As Seen On TV Toy Expert? Answer questions, earn points and help others
