I've got an older scansoft 8700 visioneer scanner that I tride to hook uop to my Dell XPS400 and it won't connect.
  • 565 Answers
Try this link to install it - link
Also what Os are u running xp or vista??
If It was helpful Rate Fixya
Posted on Dec 27, 2008
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
Jan 03, 2011 | Visioneer OneTouch 8700 Flatbed Scanner
I have replaced my xp computer with one running Vista. Will the Visioneer 6600 scanner work with Vista?
The 48-bit color Visioneer OneTouch 6600 USB scanner delivers outstanding image quality by recognizing over 281 trillion colors at 600x1200 dpi optical resolution. The scanner has three convenient buttons that integrate with the ScanSoft PaperPort Deluxe software to make emailing, copying, and storing images and text effortless. The software bundle also includes ScanSoft TextBridge Pro OCR and MGI PhotoSuite III SE.
The scanner driver is certified by Microsoft for Windows XP, and also is compatible with Windows 98, Windows 2000 and Windows Millennium Edition.
It is not compatible with windows Vista.
Apr 25, 2010 | Office Equipment & Supplies
I had a new install of windows xp (with service pack 3)on my computer and am now trying to install my visioneer one touch 8700 scanner. Is there a problem with the driver and the xp service pack 2? How can...
You will have to uninstall the device. Delete any files it created on the drive as part of the install. (Not things you'[ve scanned, just program files) then disconnect the scanner. Reattach the scanner in a different USB port (different SCSI id if your using SCSI) and let Windows re-detect the scanner.
This time don't run the setup from the driver CD. Instead let Windows find the scanner and try and set it up on it's own, if it prompts you for a driver, point it to the INF file in the installer directory. If it doesn't, let it use the one it chooses.
After installing in this way you should be able to use the scanner as a TWAIN source from any application.
Apr 19, 2010 | Visioneer OneTouch 8700 Flatbed Scanner
My visioneer one touch 8700 scanner shows up not
Hi Margaret,
I think are you using windows Vista and Visioneer one touch 8700 won’t work with that but this scanner work with Windows XP with SP 1 / 2000 Pro / Me / 98SE
And Thanks.
Mar 27, 2010 | Office Equipment & Supplies
Need drivers for windows xp pro 64
The XP driver is available at:
There is no indication of 64-bit or 32-bit support. However, the driver is not guaranteed to work with XP SP2 (only tested with SP1). This suggests that SP3 is also not tested.
I wish that I could be of more help.
Mar 25, 2010 | Visioneer OneTouch 8700 Flatbed Scanner
I lost my scanner icon from taskbar scanner will not work properl
Right click on the taskbar go to properties then click on customize button and select the appropriate icon u want.
May 01, 2009 | Office Equipment & Supplies
I have lost the CD to my Visioneer one touch 8700 usb
this is the site where you can download your driver. just follow the instructions:
Feb 17, 2009 | Office Equipment & Supplies
Visioneer One Touch 8700 USB Scanner lock mechanism problems
Not sure if your problem is the same as mine, but I encountered the same error and only to find that I plugged in a wrong power adapter so it didn't have enough power to advance the scanner head (My moving caused this mixup). Check your power adapter OUTPUT is 12V (or whatever is specified on the scanner itself, usually found on the label on the bottom or rear).
Jul 25, 2008 | Visioneer One Touch 7600 USB
Open Questions:
My Ricoh 3035 / Savin 8035 prints uniformly light pages, and tells me to add toner, with a FULL toner bottle. The developer unit itself is completely packed with toner. There are no other errors set. The issue described is recent, within the last 500 copies. Prior to that this machine was running perfectly. I've had this copier for a couple of years. It was used. It NOW has 617,871 prints/copies/faxes as of today. I replaced the developer unit remanufactured and new developer at 591,810. The transfer belt and cleaning blade are new at 607,638. I replaced the PCU with a completely remanufactured unit at 607,688. The fuser was replaced with remanufactured unit also at 607,688. I was STILL having some issues with bad quality copies, so I narrowed the matter down to a defective drum in the remanufactured PCU. I replaced the drum, and at THAT time, I installed every part in the Savin Maintenance Kit PMB082150K, which I previously received with the copier. I also replaced the PCU Entrance Seal and tape the long mylar one at the top of the drum. When I installed the developer unit, I initialized the settings, pursuant to the Service Manual, and the same with the drum, and the appropriate one each time I previously cleaned the ID Sensor Today, I went through the trouble of replacing the ID Sensor, initialized the same, and it made no difference. The copier has run just fine for the last couple of months, and then as I stated in the question, about 500 copies ago, all of the copies suddenly became light. No, it's not the density setting. I've done everything except do a factory reset. Incidentally, I have the Ricoh 3035 Service Manual, and also the Parts Manual. Experientially, the only computers I have ever purchased are 2 of them, for my office, in 10 years. Other than that, I have built every computer I've ever made, from parts. As far as this copier, I have done the copier maintenance, per the maintenance schedule, myself, and when it appears that maintenance needs to be done. This problem however, is driving me nuts. As I said, the only symptoms of the light copies are that add toner light that comes on periodically, and toner absolutely packed into the developer unit entrance such that its spills out when I remove the PCU. One last thing, and this is an when all else fails kind of thing: since the toner bottle is full, I open the front door, and using a channellock, I fix the add toner problem by rapping very lightly on the end of the PCU, and the developer unit! This DOES fix the toner out problem every time, but it does NOT fix the light copies. Simply opening the door, sliding the toner carrier out, putting it back, and then closing the door, and repeating that process a couple of times sometimes also works.
Jan 21, 2019 | Ricoh Aficio 3035 Digital...
35 people viewed this question
k24674
Marvin
Marvin
