RCA digital flat amplified antenna looses signal on one channel.
I have a RCA digital flat amplified antenna that does great on all channels and delivers clear sharp pictures. I live in Irving, Texas. One channel looses the signal when I turn the TV off and when I turn it back on, I have to pick up the antenna and move it around to get the signal back for that one channel. The TV is a SONY Bravaria 32 inch. I have tried the antenna with and without the amplifer. I have tried various places around, above and below the TV for reception. I have loaded and reloaded the channels from the menu. The antenna works very well on all HD channels and delivers a clear sharp image. Channel 8.1 (ABC) will not hold the signal once the TV is turned off and turned back on.
  • 395 Answers
SOURCE: i bought a 32" conia
well it's the same as the days of old, the antenna has a range of reception. the further the sations antenna, the lager your antenna must be. just because you bought an amplified antenna does not mean you will receive the deep fringe station. also the antenna must be UHF and VHF to receive the broadcast in digital. most of the braodcasters have gone with the UHF band because it is more stable for the bandwith of digital broadcast. the UHF band is very directional as well, so you must be pointing to the broadcasters antenna. no set top antenna will work if you are further than 15 miles of the broadcasters antenna. the roof top UHF/VHF antenna with a preamp is the way to go. I have tested every compact antenna and unless you live in the city that the broadcast generates you will get no reception with these. terks are junk, and any small amplified antenna does not work if you are in low lying areas. roof top, roof top,.....ROOF TOP!!!!!
Posted on Apr 24, 2008
robotek
  • 1512 Answers
SOURCE: Would you confer with me on this couple in Australia
If they are looking for analog ABC, it is low band VHF, ch2 to be exact,where the rest are high band VHF, and needs a decent multiband antenna to get it in alot of areas, well in Brisbane at least. We have Mount Coot-tha that has a good propagation to most metro areas approx 40km radius, although it starts to get a bit noisy on the ABC due to lowband interference issues. .
There are many areas of AU that use UHF for TV also. Not enough hills in many parts of the east coast to get the coverage, so there can often be UHF translators that you need to tune onto. I suspect the ABC problem does relate to them not using an antenna that is suited to VHF, saying this of course if they get the other channels (7,9, and 10) ok.
Go here for a more specific channel/frequency guide to determine if it is the problem by location. ABC is on different channels almost depending on what suburb you are in for some areas. If the DVR can do digital, then they should go that way as it is now UHF ch21. It may be that they are trying to get analog signals, that will be turned of in the near future... so tuning the system in for UHF propagated digital is the way to go.
Back in the day when I used to do antenna I recommended the Hills PF11 antenna, multiband 11 element yagi with low/high band VHF/UHF, or a PF17 (17 element) with mast head amp if they are in a marginalised signal area. But a UHF array is still the best way to go if they can process a digital signal. Hope that helps :)
regards
robotek
Posted on Oct 23, 2008
Shuttle83
  • 1139 Answers
SOURCE: No antenna reception with digital converter box.
Hello Faznmc,
I have found that with an ordinary antenna connected to the converter box it can receive nearly all channels, however I have run into cases where I had to use an amplified TV antenna to pick up signals. I have started telling folks that when they install their converter boxes to try to use the plain old rabbit ears antenna, but if that does not work, use an amplified antenna, and that usually does the trick.
I hope this helps
Thank you,
Shuttle83
Posted on Nov 03, 2008
  • 5 Answers
SOURCE: digital tv antenna reception
try googling how to build an antenna with coat hangers. not pretty but cheap!
Posted on Apr 18, 2009
  • 30 Answers
SOURCE: local ABC and PBS stations do not come in. All others local stat
Check to make sure your DTV antenna is an "all band" antenna with reception in both the UHF and VHF bands. It sounds like you may be in Philadelphia area. In Philadelphia, all the DTV stations are in the UHF band except Ch 6 and Ch12, which are in the VHF band. Some of the DTV antennas are UHF only. You can tell if yours can receive VHF if it has the "rabbit ears" long wip antennas. If so make sure the whips are extended fully and turn the antenna to try to get a good signal.
Visit the 6ABC and WHYY websites for up to the minute information about the issues with reception issues.
Posted on Jun 16, 2009
Is the Ematic AT103B Converter Box compatible with Suddenlink cable/digital service?
No, the Ematic AT103B is an over-the-air digital ATSC tuner and will also can convert the digital signal to analog NTSC for older TV tuners. It will not work with any cable service and is for "cord-cutters". The AT103B requires an antenna to receive your local OTA channels. Depending on where you live, you may get some channels with an indoor antenna. You will get better reception with an outdoor antenna. See http://www.tvfool.com or http://www.antennaweb.org for details on the channels you can receive with an antenna pointed in a particular direction.
The Ematic set top box does provide an HD signal output and a DVR (time-shift function) so it is more advanced than the first generation OTA converter boxes. The original (available with the government coupon) converter boxes only gave an SD output.
I hope this helps.
(antennaweb.org gives a very conservative list of available channels but assumes an external antenna. tvfool.com lists the channels that are likely to be received with a variety of antenna strengths. An antenna signal amplifier can improve the reception. (Digital stations will not be seen if the tuner can't lock onto the signal.) However, when the amplifier fails, you may find some channels will not be received at all.)
Dec 08, 2016 | Televison & Video
How do i get hd channels with no cable ? just antenna
If your TV has a digital tuner, you can get any HD channels if you use the correct antenna pointed at the transmitter and are close enough to the transmitters. (Antennas labeled as HD are not always appropriate for your location.) Your TV will downgrade the signal to 480i if the TV can't support a 720p or 1080i resolution.
First where do you live? Use antennaweb.org or tvfool.com to determine the correct placement of your antenna for your area/stations. AntennaWeb uses a very conservative signal strength calculation despite assuming an external antenna. Tvfool will give the antenna color rating which is also provided on the antenna package. When properly installed (with no trees or hills blocking the signal), the matching antenna should receive the listed channel.
If you use a splitter to share the signal with several TVs, you may need an amplifier to bring the signal strength to that needed for the tuner to interpret the digital signal. (Note: amplifiers and splitters can fail and the amplifier may become a signal filter blocking the signal; test the antenna strength on a direct connection if there is a problem.)
If you do not have a digital tuner in the TV, you may have gotten an SD digital to analog converter. These are the more common (and available with the government coupon) converters. You will need to get an HD capable tuner to see the full HD signal.
Please add a comment with your TV model and antenna choice for additional support.
(antennaweb indicates that my external antenna should only get the stations 10 miles away. We actually receive the channels from 30 miles away. We use an amplifier splitter to feed the signal to several TVs. I set up two indoor antennas for a neighbor's TVs. One gets the signals from the transmitters 30 miles away and the other from the transmitter 10 miles away. Both get HD from the stations with HD broadcast (not all channels are in HD here). The difference is totally due to antenna placement.)
Aug 10, 2012 | Hisense Televison & Video
I hooked up an indoor antenna to the TV and select ANT as an input from the menu. Still can't get any channels at all.
First try moving your antenna around (see the sites listed below for the direction to point the antenna to get a signal). If the antenna has an amplifier, try unplugging that unit. (When an amplifier fails, no signal gets transmitted.) Similarly if you have several TVs sharing one antenna, remove the splitter and directly connect the antenna to this Toshiba to make sure that it isn't causing the problem.
You may be in an area where an iindoor antenna may not work for you. Tall buildings and trees can scatter the signal to the point where a digital tuner can't get enough signal to "read" the data. Again use the results from the sites listed below to check what stations are likely to be received in your area.
Different TVs have different tuner sensitivities. An amplifier may help bring in enough signal to get the channels. (Signal loss is inevitable. However, if the signal is sufficiently poor, an amplifier may give you more noise and won't help.)
There are two sources for a site specific list of channels: Antennaweb.org and tvfool.com . Antennaweb assumes an external antenna and is very conservative in the list of channel that you should receive. (It lists two channels from one transmitter in my area.) Tvfool will indicate the channels that you should get with different antennas (indoor, outdoor, amplified signals).
A rare issue can be that the tuner in the TV has failed. The only way to check that is trying the TV with different antennas (or in different areas - one with high signal strength).
I hope this helps.
(ATSC (digital OTA signals) are either enough to read or not. You can't get the fuzzy signal of an edge of range analog signal.)
Aug 15, 2011 | Toshiba REGZA 47HL167 TV
Terk od amplified indoor digital antenna installed after install of wintv-hvr 1600 internal hdtv card. win7 opens, followed instructions to scan for atsc digital tv.....NO CHANNELS FOUND. cables...
Unless you are very close to the TV transmitter aerial it is very unlikely that you will get adequate signal for digital TV with an indoor antenna. Check with your neighbours to see what they use and where the nearest transmitter is.
Unfortunately, with indoor an antenna, the amplifier also amplifies any electrical interference from other devices in the building.
First step would be to try taking it outdoors (use an extension cord to get well away from any buildings, trees or large metal objects that could block the signal).
Feb 09, 2011 | Terk FDTV1A Flat Digital OmniDirectional...
How do we change a channel to accept VHF
You can use the remote and push the input button until it shows digital channel. But in order to get VHF you need the access the channel search in menu. You also will need a descent "digital" antenna as the Digital signal is no where near as relaible as analog was. Also older antanna's do not seem to work very well with the digital signal. I recommend an outdoor version because a single wall can interfere with digital signal. If thats not an option get a descent amplified indoor antenna. If you do a channel search without an antenna more than likely you not find any channels.
Dec 14, 2010 | Samsung Televison & Video
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
HDTV unable to get HD Channels w/ Antenna
The problem could be your antenna. Many people will buy small indoor tv antennas and wonder why they're not getting the signal that they want or the channels that they expect. Its not your fault. Digital signal is in two formats: UHF AND VHF. Some antennas only receive UHF. But many of the low band channels are VHF, so 1) you need an antenna that will receive those signals and 2) you need to know how and where to install that antenna and 3) you need to know if you need a signal amplifier depending on your coaxial cable length and number of connections. I recommend visiting dennys antenna service (no I don't work there and I have never purchased anything from that website. He just has an excellent informational article with a great deal of "how to" on his pages.). http://www.dennysantennaservice.com/2029710.html This should be of great help to you. Happy viewing =)
Dec 26, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Mike
Mar 22, 2009 | Televison & Video
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
