Question about Dell Latitude D810 Notebook
Hello, The batery light on my PC (latitude D810) is allways blinking (from green to orange). Could you describe what is the problem? Thank you.
  • dblane810 Feb 24, 2009
    When plugged in, the battery light flashes 3 times yellow then once green. Problem is the battery is not charging. Shows that it is charging but remains at 0%. A bad battery?
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
My Toshiba power light blinks only when I try power on. The ligth blinks 5 times, 2 times and 5 times again. The batery light turn off after power on. When i connect the power cord, the power ligth is...
you should check this thread out http://www.hardwareanalysis.com/content/topic/51345/
also if you need to convert from binary to hex use this link
http://easycalculation.com/hex-converter.php
Mar 21, 2011 | Toshiba Satellite 2400-S251 Notebook
Very dark display screen almost black,dell latitude d810
Hi
Thank you for your query
Please try the following key combination
fn + Up Arrow
fn + Right arrow
If the above fail then it will be the inverter of the screen which will need to be replaced, please book the laptop into a reputable PC shop for replair
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 22, 2010 | Dell Latitude C610 Notebook
Dell latitude d810 will not boot up; stuck after dell logo.
boot file is corrupt...
re-install OS
visit my site
http://www.sureshayyar.110mb.com/
FormatDisk page has all resloution of problem
Jan 16, 2010 | Computers & Internet
Dell latitude d810 battery light flashes 4 orange and one green
This indicates an internal failure in the battery. While the battery may hold a charge and function, the system has determined an internal failure (Cell with low or no voltage etc) and the only way to resolve the failure is to replace the battery
Dec 19, 2009 | Dell Latitude D810 Notebook
My battery light is blinking 4 times orange, 1 time green. I have a Dell latitude d830.
battery is dead - if under warranty get it replaced, on batteries warranty is only good for 1 year on dell's. cheers!
Sep 30, 2009 | Dell Latitude D830 Intel Core 2 Duo T7250...
Dell laptop battery has 3 lights flashing when hit battery tester
You can't get the modern batteries to come back to life. Time to get a new one.
A suggestion: When using a laptop battery, run it on battery and discharge it until it shows about 2 to 3% charge left at least once a month. Do not keep charging it without letting it run down periodically. Most important--do not run always plugged in to line current.
Sep 09, 2009 | Dell Latitude D810 PC Notebook
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Jan 24, 2009 | Dell Inspiron 5160 Notebook
Blinking battery lights
Is this the charging LED? If so, you've either got a bad battery or a bad system board.
Dec 14, 2008 | Dell Latitude C400 Notebook
Dell Latitude D810 Notebook Logo
199 people viewed this question
Alun Cox
